Older intel fortran compiler
chatten_ist_fun
I am using the intel fortran compiler version 9.0.021 and I need it to run an OpenMP Benchmark.
I am running it in a simulator which is not executing the compiler because of a segmentation fault.
I guess it fails because the simulator does not support the PentiumII Instruction Set.
Question: Where can I get an older version of the intel fortran compiler that supports openmp and runs on an older i386 architecture?
Thank you very much!
TimP
Even the latest 32-bit 9.1 compiler supports the old instruction set from before Pentium II as the default. If you have a full license, you can download some fairly old compilers, using your premier.intel.com account, but I don't see how this could make a difference in that respect.
What processor model does this simulator simulate? We do not have available compilers that support 386 processors.
