29276 Discussions
Can a procedure argument be optional?
eos_pengwern
I have in my program a subroutine of the form...
[bash]    subroutine MapCentre(fitobj, centre_x, centre_y, sidelength, image, callback, c_object, error)
        type(FitObject), intent(inout), target :: fitobj
        integer, intent(in) :: centre_x, centre_y, sidelength
        integer(4), intent(out), dimension(:,:), target :: image
        type(c_ptr), intent(in) :: c_object
        integer, optional, intent(out) :: error
        interface
            subroutine callback(c_object) bind(c)  ! N.B. 'bind(c)' implies 'external'
                use, intrinsic :: iso_c_binding
            end subroutine callback
        end interface
    end subroutine MapCentre[/bash]
I'd like to make the arguments 'image', 'callback' and 'c_object' to be optional. It's obvious enough how to do this with the parameter arguments, but where would I put the word 'optional' within the procedure interface? Is this even possible?
Stephen.
Steven_L_Intel1
You do it with an abstract interface and PROCEDURE. Like this:
[fortran]    abstract interface
        subroutine callback_int(c_object) bind(c)  ! N.B. 'bind(c)' implies 'external'
        end subroutine callback_int
    end interface
        procedure(callback_int), optional :: callback
    end subroutine MapCentre  [/fortran]
Steven_L_Intel1
    end interface
eos_pengwern
Looks like just the ticket. Thank you Steve.
