29651 Discussions
Can't compile code that use a use a shared variable (User defined Type) from a module...
toreleraand
When trying to compile a subroutine that access a common variable from a module, the compiler just returns :"Compilation Aborted" ...(code 3). WHat is special about the variable is that it is a user defined TYPE with internal arrays.(The compiler does not complain when compiling routines that accesses module-variablesthat are arrays of User Defined types.)
Compared to the CVF environment, is there something wrong with having arrays in a TYPE, ...is this treated differently with the Intel compiler? I have no other TYPE definitions with array variables inside. (Normally I have arrays of TYPES, not the other way around)
Tore
Here is the code-snippet from the module itself:
TYPE TERR1D_STRUCTURE
SEQUENCE
REAL*8 KP(1:Nterr1Dmax)
REAL*8 Z(1:Nterr1Dmax)
REAL*8 Lat(1:Nterr1Dmax)
REAL*8 Lon(1:Nterr1Dmax)
Integer*4 N
Integer*4 Padding
END TYPE
COMMON /COM_TERR1D/ Terr1d
SAVE /COM_TERR1D/
!DEC$ ATTRIBUTES DLLEXPORT :: /COM_TERR1D/
!DEC$ ATTRIBUTES ALIAS:'/COM_TERR1D/' :: /COM_TERR1D/
TYPE(TERR1D_STRUCTURE) Terr1d !
The module created from the above code is then used from a subroutine in a static library. The subroutine won't compile as long as I try to reference the arrays in the type, as illustrated below:
use moeTypes !...this is the module name
real*8 dummy
dummy=terr1D.KP(i)
You encountered an internal compiler error. This is always a compiler bug. If it still happens with a current compiler, please report it to Intel Premier Support. If you don't want to do that but would like me to see if the problem still exists, e-mail me the sources to steve.lionel at intel.com
