Catastrophic Compiler Error related to abstract interface and procedure pointers
gtokic
Hi everybody,
When accessing a function through a pointer defined by an abstract interface, I get internal compiler catastrophic error. The example code is the following:
module modl
  implicit none
  integer    :: m
end module modl
module type_def
  implicit none
  type mytype
    real   :: a,b
    integer  :: n
  end type mytype
end module type_def
module function_def
  implicit none
  abstract interface
    function func(a)
      use modl,         only : m
      use type_def,       only : mytype
      implicit none
      class(mytype),intent(in)    :: a
      complex                     :: func(m*a%n)
    end function func
  end interface
  procedure(func),pointer   :: p => null()
 contains
  subroutine evaluate_fun(a)
    use modl,      only : m
    implicit none
    type(mytype),intent(in)  :: a
    complex                  :: res(m*a%n)
    res = p(a)
    print *,' evaluate_fun: res = ',res
  end subroutine evaluate_fun
  subroutine set_pointer()
    implicit none
    p => myfunc
  end subroutine set_pointer
  function myfunc(a)
    use modl,      only : m
    implicit none
    complex                   :: myfunc(m*a%n)
    myfunc = 1.0
  end function myfunc
end module function_def
program test_catastrophic
  use modl,         only : m
  use function_def, only : set_pointer,p,evaluate_fun
  implicit none
  type(mytype)   :: a
  complex        :: res(15)
  a%n = 5
  m = 3
  call set_pointer()
  call evaluate_fun(a)
  res = p(a)
  print *,'main program: res = ',res
end program test_catastrophic
The program reports the following error while compiling:
0_12459
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
If function evaluate_fun is not present in the module function_def (and of course not called in the main program), the program compiles and runs as expected. Why does it break down when the function is accessed (through pointer p) in the module procedure, but not when accessed from the main program?
The program also runs if the function interface is changed to include m as a dummy variable, but that solution isn't easy to implement in the actual code.
The Fortran version is:
> ifort -v
ifort version 12.1.0
I would appreciate any ideas, suggestions or explanations.
Grgur
Simon_Geard
I can't help you with that directly but I can tell you that your code compiles and runs on the latest compiler:
U:\>ifort t.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.3.202 Build 20140422
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 10.00.30319.01
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:t.exe
-subsystem:console
t.obj
U:\>t.exe
  evaluate_fun: res =  (1.000000,0.0000000E+00) (1.000000,0.0000000E+00)
 (1.000000,0.0000000E+00) (1.000000,0.0000000E+00) (1.000000,0.0000000E+00)
 main program: res =  (1.000000,0.0000000E+00) (1.000000,0.0000000E+00)
gtokic
Hi sgeard,
Thanks for your tip! I will see if we can get the new version of ifort installed. So no ideas what might be wrong when calling the pointer-assigned function from the same module (i.e. using evaluate_fun subroutine)?
Grgur
Steven_L_Intel1
You encountered a compiler bug that was fixed. It's not worthwhile to ask "what might be wrong" at this point.
gtokic
Hi Steve,
Thanks for letting me know. I was asking because I was not sure whether it's my bad coding or is it really ifort's bug.
Best,
Grgur
Steven_L_Intel1
An internal compiler error is ALWAYS a compiler bug, even if it is prompted by a source error. Since sgeard reports that the program builds and runs with a current version, it's pretty likely not a source error.
gtokic
Thanks a lot for your help!
