Check just first condition in if statement if false?
Andreas_G_
Hello, and thanks in advance for the help
I am porting some code from Linux and am purturbed that the following, which worked with the Portland Group Compiler for the case when L=0, does not work now:
      IF(L .GT. 200 .AND. AERO(L) .GT. 2.0) THEN
           CALL ....................
      ENDIF
In IVF, I must apparently to do this, otherwise it complains about AERO(0):
      IF(L .GT. 200 ) THEN
         IF( AERO(L) .GT. 2.0) THEN
         ENDIF
      ENDIF
Does IVF always check all conditions in an IF, even when the first one fails? I’m going to have to do a lot of rework if true. Someone in the office suggested turning off subscript error checking, but I still want to able able to trap other instances of subscript out of bounds. Is there a flag to make IVF stop checking when it finds a false IF condition?
Andy
jimdempseyatthecove
It is a language requirement that Fortran to be able to check in any order and check all logical (sub) expressions. Sorry, you will have to use the THEN. I advise against relying on turning off subscript checking. That will trip you up at times (bogus index producing SIGSEV for invalid memory access).
Jim Dempsey
Andreas_G_
Thank you Jim
I may have preferred a different answer, but now I have it. In any case, I'll have more robust code.
Thanks!
Andy
