29280 Discussions
Checking values of the function returning the link to a file
postaquestion
At work with a debugger it is impossible to check values of the function
returning the link to a file of variables of any type.
The example belowmentions the link to a file is returned with function TEST1. If to stop at debugging in the given function value of her cannot be checked. It is desirable to correct this position.
MODULE NNN
CONTAINS
FUNCTION TEST1(C)
REAL*8, POINTER :: TEST1(:)
REAL*8 C(:)
INTEGER IKL
IKL=SIZE(C)-10
ALLOCATE (TEST1(IKL))
TEST1=10
END FUNCTION TEST1
END MODULE NNN
PROGRAM TEST
USE NNN
REAL*8 , POINTER :: TTT(:)
REAL*8 , POINTER :: RRR(:)
ALLOCATE (RRR(100))
RRR=100.D00
TTT=> TEST1(RRR)
END PROGRAM
