CoArray HYDRA_BINDING
jimdempseyatthecove
Using an MPI program I can specify -bind-to object (board, numa, socket, core, hwthread) to affect where and how many of the objects to assign to a process (rank).
CoArrays uses MPI, but the "mpiexec [options]" program
is cleverly hidden.
In the Coarray section of the dev guide document it suggest using a configuration file, but only curtly says to consult the Intel MPI Library.
The MPI Library reference (as looking though the index and by searching), shows how to specify the path/name of the configuration file. By I am stymied as to how to find out the content rules for the configuration file.
For an MPI application, I can use -bind-to to attain what I want.
The environment variable HYDRA_BINDING appears in one place in the Intel documents, but there is no indication as to if when launching a coarray application, that the contents of this environment variable are use for the value of the -bind-to option.
Can anyone point me to a description of the content of the MPI configuration file as used by IVF Coarrays and/or if environment variable HYDRA_BINDING is used by IVF Coarrays.
Jim Dempsey
Barbara_P_Intel
Did you see this article? There is an example of a config file.  It is target to a distributed environment, but that might just help.
Barbara_P_Intel
jimdempseyatthecove
Thanks, that is just what I need.
It would have been nice if this information (or link to) was in the index of the compiler documentation.
Happy New Year
Jim Dempsey
andrew_4619
Beware the children of the Hydra's Teeth....... (Been watching old movies)
