Coarray sync problems
Jan_W_2
Is there a way to resolv coarray sync issues with vtune? Is there maybe
a tutorial for this?
Thank you
Jan
Please describe the problem in more detail. VTune Amplifier XE won't help with coarray issues as MPI is used. Intel Trace Analyzer and Collector can help with this.
Jan_W_2
Dear Steve,
it is a transpose-free QMR solver. I want to use coarrays for parallelize the matrix-vector product.
Unfortunally, if I use more than one image the calculations slow down.
This is the matrix-vector product routine:
subroutine matvec(a,x,y)
      type(coo_matrix), intent(in)       :: a
      complex(dp), dimension(:), intent(in) :: x
      complex(dp), dimension(size(x,1)), intent(out) :: y
      complex(dp), allocatable,dimension(:)  :: tmp[:]
      integer :: i, me, numi
      me   = this_image()
      numi = num_images()
!allocate
      allocate(tmp(a%n)
  • ) y = cmplx(0.0_dp, 0.0_dp,dp) tmp = cmplx(0.0_dp, 0.0_dp,dp) !sync sync all !Add locally all do i = 1, a%loc_nnz tmp(a%ir(i)) = tmp(a%ir(i)) + (a%val(i) * x(a%jc(i))) end do !sync sync all !Sum all coarrays together y = globalSum_serial(tmp, a%n) !deallocate deallocate(tmp) end subroutine
  • And the sum function is:
    function globalSum_serial(vec,n) result(this)
        complex(dp), dimension(:), intent(inout) :: vec
  • integer, intent(in) :: n complex(dp), dimension(n) :: this integer :: i, me, numi me = this_image() numi = num_images() sync all if(me == 1) then do i = 2, numi vec(:)[1] = vec(:)[1] + vec(:) end do this(:) = vec(:) end if sync all if(me /= 1) this(:) = vec(:)[1] sync all end function
  • I compile this with ifort 15.0.1 using only -coarray.
    When I use a big matrix the more images I use the matvec routine will slow down.
    I did a basic hotspot analysis with vtune and it says that
    ICAF_BARRIER and ICAF_UNLOC are the code segments which need the most time.
    Thank you jan
    What happens if you replace:
    with:
    vec(:) = vec(:) + vec(:)
    Jan_W_2
    I tried it but it doen't help ... the calculation speed is as before.
    Thank you
    Jan
    Is VTune telling you where those synchronization calls are coming from in your code? Trace Analyzer and Collector's timeline display can be helpful in understanding what is happening.
    Jan_W_2
    Dear Steve,
    I checked the Vtune analysis again, and it is telling me that the barriers are in the globalSum_serial function.
    I also checked the times how long each image needs for summing. They all need more or less the same time.
    Thank you,
    Jan
    reinhold-bader
    New Contributor II
    What you are doing in your globalsum procedure is a cross-image reduction; while this is formally correct, it is quite inefficient. The statement that is particularly inefficient is the last communication statement
    which oversubscribes the network link to image 1. The only "good" solution to this is using a collective call, which presently is not yet defined for coarray Fortran (but hopefully soon will be). For now, I think using MPI_Allreduce in its place should work (some MPI boilerplate may be needed). The alternative would be to implement the reduction manually, using all images (e.g. with a butterfly communication pattern) to reduce the amount of synchronization and avoid oversubscription.
    Cheers
    Reinhold
