Compilation Error
Michael7
The following directive in the beginning of my code (partially shown below)
!DEC$OBJCOMMENT LIB:'INLATHENA.LIB'
      Options /EXTEND_SOURCE
      Program MAIN
!:Variable Declarations Section
      Implicit None
causes the Intel compiler v16.0 Update 1 (pack 146) to issue the following error:
ALG01.FOR(3): remark #5082: Directive ignored - Syntax error, found HEX_OCT_BIN_CONSTANT 'BINLATHENA.LIB' when expecting one of: <CHARACTER_CONSTANT>
There was no problem with the Compiler version 11.1. Does this mean that I can no longer use the above directive or is there a workaround?
Michael
Put a space after !DEC$. We fixed a bug in support of continued directives, which means that the blank after the prefix is not optional in fixed-form source.
Michael7
Thank you very much Steve
I truly appreciate your help. Your suggestion worked perfectly.
Merry Christmas and Happy New Year
Michael
