29285 Discussions
Compiler 8.1 under Suse9.1 on AMD64.
a_boswell
We are considering installing:
Intel C++ Compiler 8.1 and
Intel Fortran Compiler 8.1 on a AMD64 Beowulf cluster running under Suse 9.1.
Please can you tell me if this:
- install OK
- build 64 bit binaries making use of the 64 bit extension under AMD64
- has it been shown to run MPI and PVM code under these platforms?
- are there known Suse installation problems?
Thansk
Andrew
I don't know about MPI and PVM specifically, but we do support SUSE 9.1. You will need to download our compiler for Intel EM64T from Intel Premier Support - look for the kit with a file name starting with l_cce and l_fce. Use the -xW switch when compiling for AMD64.
