29657 Discussions
Compiler ICE with OpenMP (since version 15...)
Jauch
I have the following piece of code:
    subroutine THOMAS_2D_NewType(IJmin, IJmax,                                &
                         JImin, JImax,                                        &
                         di,    dj,                                           &
                         THOMAS,                                              &
                         ANSWER,                                              &
                         ModelName)
        !Arguments-------------------------------------------------------------
        integer,                         intent(IN) :: IJmin, IJmax
        integer,                         intent(IN) :: JImin, JImax
        integer,                         intent(IN) :: di,    dj
        type(T_THOMAS2D), pointer                   :: THOMAS
        real,    dimension(:,:), pointer            :: ANSWER
        character (len=*), optional                 :: ModelName
        !Local-----------------------------------------------------------------
        integer :: IJ, JI, II, MM, I, J
        type(T_VECGW), pointer                      :: VEC
        integer                                     :: TID
        !$ integer                                  :: CHUNK !
        real                                        :: AUX
        !Begin-----------------------------------------------------------------
        !$ CHUNK = CHUNK_J(IJmin,IJmax) !
        !$OMP PARALLEL PRIVATE(TID,VEC,IJ,I,J,JI,II,MM,AUX)
        TID = 1
        !$ TID = 1 + omp_get_thread_num() !
        VEC => THOMAS%VEC(TID)
        !$OMP DO SCHEDULE(DYNAMIC,CHUNK)
do2 :   do IJ = IJmin, IJmax
            I = IJmin-1 + IJ*dj + di
            J = JImin-1 + IJ*di + dj
            VEC%W(JImin) = -THOMAS%COEF2%F(I, J)/THOMAS%COEF2%E(I, J)
            VEC%G(JImin) =  THOMAS%TI(I, J)     /THOMAS%COEF2%E(I, J)
do3 :       do JI=JImin+1,JImax+1
                I        = IJ*dj + JI*di
                J        = IJ*di + JI*dj
                AUX = THOMAS%COEF2%E(I,J) + THOMAS%COEF2%D(I,J) * VEC%W(JI-1)
                if (abs(AUX) > 0) then
                    VEC%W(JI) = -THOMAS%COEF2%F(I,J) / AUX
                    VEC%G(JI) = (THOMAS%TI(I,J) - THOMAS%COEF2%D(I,J) * VEC%G(JI-1))/ AUX
                else
                    VEC%W(JI) = 0.
                    VEC%G(JI) = 0.
                    write(*,*) 'ModelName I, J: ', trim(ModelName), ' ', I, J
                    write(*,*) 'Error: Instability in THOMAS2D - ModuleFunctions - ERR10'
                end if
            end do do3
            I = IJ * dj + (JImax+1) * di
            J = IJ * di + (JImax+1) * dj
            ANSWER(I, J) = VEC%G(JImax+1)
do1 :       do II = JImin+1, JImax+1
                MM = JImax+JImin+1-II
                I  = IJ*dj + MM*di
                J  = IJ*di + MM*dj
                ANSWER(I,J) = VEC%W(MM) * ANSWER(I+di,J+dj) + VEC%G(MM)
            end do do1
        end do do2
        !$OMP END DO NOWAIT
        !$OMP END PARALLEL
    end subroutine THOMAS_2D_NewType
It compiles til the fortran version 14.0.3
From version 15 and up (til 16.0.1), this causes an ICE.
The ICE happens only on Linux. On Windows it compiles ok (up to 15.0.4, I do'nt have 16 and 16.0.1 on Windows).
Can you help me figure out if there is something wrong with this code?
Thanks in advance!
Eduardo
jimdempseyatthecove
Is this a contained subroutine? I see no definition of T_THOMAS2D, T_VECGW and CHUNK_J (there may be others).
Nothing stands out of place when I look at the code. Add IMPLICIT NONE and compile with the interface checking. See what shows up.
The NOWAIT isn't going to do anything for you as there is no code following the !$OMP END DO.
Jim Dempsey
Jauch
Hello Jim,
This is a Module routine.
Chunk_J is another routine in this module:
    integer function Chunk_J(JLB, JUB, factor)
        integer, intent(IN)                         :: JLB, JUB
        integer, optional, intent(IN)               :: factor
        !Locals----------------------------------------------------------
        integer                                     :: factor_
        if (present(factor)) then
            factor_ = factor
        else
            factor_ = ChunkJFactor
        endif
        Chunk_J = max((JUB - JLB) / factor_, 1)
    end function Chunk_J
T_... are types within the module.
I'm sending this module (and it's dependences) attached to allow you to compile it and see the error:
catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
The line I'm using to compile is this:
-g -gen-interfaces -warn interfaces -check all -openmp -fpp -r8 -std03 -m64 -ip -zero -xHost -axAVX -O3 -parallel -inline-level=1 -assume buffered_io -warn all -nologo -convert big_endian -fpe0 -D_USE_NIX -traceback -mcmodel=medium -shared-intel -openmp-link=static -static-libgcc -heap-arrays 64 -c -D_LAGRANGIAN_GLOBAL_ -D_COMPILED_BY=\"user\" -D_NO_NETCDF -D_STACK_LIMITS
Cheers,
Eduardo
Jauch
I missed one file.
