29632 Discussions
Compiler Options vs. Command Line
lklawrie1
I think this has been answered or discussed here before but I searched and couldn't find it.
In CVF, one could copy the command line options from the windows and automatically populate the right check boxes and so forth. This apparently does not work in IVF?
Does IVF still use those options as copied?
Is the team working toward having that populate the check boxes?
Thanks for any help with this. I've moved ahead and have been using IVF for quite a while on my team. Now, others are coming along but want to use the same options as I or at least know what I've been using as I do the copying for release.
Linda
Jugoslav_Dujic
Valued Contributor II
FWIW, even if you can't do that from GUI, it's fairly easy to do that from a text editor, since .vfproj files are quite readable. See for yourself -- take a look at:
Further down, differences in settings (if any) for individual files to the project settings are listed.
HTH,
Jugoslav
