Compiler bug?
Clive_J_1
Hi
I attempted to compile my code but the compiler crashed. I have managed to isolate the problem in the following skeleton code.
PROGRAM DEMO
IMPLICIT NONE
INTEGER :: LengthString
INTEGER :: I
CHARACTER(LEN=:), ALLOCATABLE :: String(:)
LengthString=10
ALLOCATE(CHARACTER(LengthString) :: String(10))
DO I=1,10
  IF(I*2/2 == I) THEN
    String(I) = 'abcdefghij'
  ELSE
    String(I) = 'nopqrstuvw'
  ENDIF
ENDDO
DO I=1,10
  IF(String(I)(1:1) == 'a') THEN
    WRITE(*,*) 'match found'
  ELSE
    WRITE(*,*) 'no match found'
  ENDIF
ENDDO
STOP
END PROGRAM DEMO
but this results with
Compiling with Intel(R) Visual Fortran Compiler XE 12.0.4.196 [IA-32]...
demo.f90
\intel_compiler_failure\intel_compiler_failure\demo.f90(23): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for C:\Users\User\Documents\oslo_vision_tortoise\intel_compiler_failure\intel_compiler_failure\intel_compiler_failure\demo.f90 (code 1)
The Fortran is standard and this is easily shown by making one of two simple changes.
The first is to define the length of the string at compile time, thus
PROGRAM DEMO
IMPLICIT NONE
INTEGER :: I
CHARACTER(LEN=10), ALLOCATABLE :: String(:)
ALLOCATE(String(10))
DO I=1,10
  IF(I*2/2 == I) THEN
  ELSE
  ENDIF
ENDDO
DO I=1,10
  ELSE
  ENDIF
ENDDO
STOP
END PROGRAM DEMO
compiles fine. However, I need to length of the string to be dynamic so a workaround is to copy the array element under test to a scalar string variable, thus
PROGRAM FUDGE
IMPLICIT NONE
INTEGER :: I
CHARACTER(LEN=:), ALLOCATABLE :: TempString
LengthString=10
ALLOCATE(CHARACTER(LengthString) :: TempString)
DO I=1,10
  IF(I*2/2 == I) THEN
  ELSE
  ENDIF
ENDDO
DO I=1,10
  TempString = String(I)
  IF(TempString(1:1) == 'a') THEN
  ELSE
  ENDIF
ENDDO
STOP
END PROGRAM FUDGE
also compiles without a problem.
Cheers
Clive
I can reproduce this error in all 12.0 and 12.1 compiler versions, but it is fixed in version 13.0 (Composer XE 2013). The current version is Composer XE 2013 Update 1.
Clive_J_1
OK Steve. I don't know when I will upgrade to the latest  version but since I have my workaround it is not a big deal.
Clive
