Compiler fails to catch rank (and attribute) mismatch with the interface in procedure pointer assignment
FortranFan
The following simple code compiles with no errors or warnings with compiler 16.0, however the procedure pointer assignment at line 33 has a rank and allocatable attribute mismatch in function result.  It'll be nice if the compiler can warn about this.
module m
   implicit none
   abstract interface
      function Iget_i() result(iarr)
         !.. function result
         integer :: iarr
      end function Iget_i
   end interface
   procedure(Iget_i), pointer :: get => null()
contains
   function get_i() result(iarr)
      !..function result
      integer, allocatable :: iarr(:)
      iarr = [ 0 ]
      return
   end function get_i
   subroutine sub()
      get => get_i
   end subroutine sub
end module m
FortranFan
Another variant of the interface mismatch problem:
module m
   implicit none
   abstract interface
         !.. function result
         integer :: iarr(1)
      end function Iget_i
   end interface
contains
      !..function result
      iarr = [ 0 ]
      return
   end function get_i
   subroutine sub()
      get => get_i
   end subroutine sub
end module m
FortranFan
And a third:
module m
   implicit none
   abstract interface
         !.. function result
      end function Iget_i
   end interface
contains
      !..function result
      integer :: iarr(1)
      iarr = [ 0 ]
      return
   end function get_i
   subroutine sub()
      get => get_i
   end subroutine sub
end module m
Kevin_D_Intel
Thank you FortranFan. I submit these to Development for their consideration.
Updated 11/19/2015: Submitted to Development
(Internal tracking id: DPD200378947)
