At one point in time w_fcompxe_novsshell_2013.1.119.exe would install in Visual Studio 2013, albeit with problems that required some files to be deleted (https://software.intel.com/en-us/forums/topic/494680). It now appears that this is prohibited. Is there a way to make w_fcompxe_novsshell_2013.1.119.exe install with Visual Studio 2013? I am moving to a new computer and would like to do this again.
See attached picture for the error message from the install.
On my old machine I have successfully installed Compose XE 2013 into Visual Studio 2013 as is shown below in the installed products list from VS2013:
Microsoft Visual Studio Professional 2013
Version 12.0.30110.00 Update 1
Microsoft .NET Framework
Version 4.5.50938
Installed Version: Professional
LightSwitch for Visual Studio 2013 06177-179-2382616-02971
Microsoft LightSwitch for Visual Studio 2013
Microsoft Office Developer Tools for Visual Studio 2013 ENU 06177-179-2382616-02971
Team Explorer for Visual Studio 2013 06177-179-2382616-02971
Microsoft Team Explorer for Visual Studio 2013
Visual Basic 2013 06177-179-2382616-02971
Microsoft Visual Basic 2013
Visual C# 2013 06177-179-2382616-02971
Microsoft Visual C# 2013
Visual C++ 2013 06177-179-2382616-02971
Microsoft Visual C++ 2013
Visual F# 2013 06177-179-2382616-02971
Microsoft Visual F# 2013
Visual Studio 2013 Code Analysis Spell Checker 06177-179-2382616-02971
Microsoft® Visual Studio® 2013 Code Analysis Spell Checker
Portions of International CorrectSpell™ spelling correction system © 1993 by Lernout & Hauspie Speech Products N.V. All rights reserved.
The American Heritage® Dictionary of the English Language, Third Edition Copyright © 1992 Houghton Mifflin Company. Electronic version licensed from Lernout & Hauspie Speech Products N.V. All rights reserved.
ASP.NET Web Frameworks and Tools 2012.2 4.1.21001.0
For additional information, visit http://go.microsoft.com/fwlink/?LinkID=309563
ASP.NET Web Frameworks and Tools 2013 5.0.11213.0
For additional information, visit http://www.asp.net/
Common Azure Tools 1.0
Provides common services for use by Azure Mobile Services and Windows Azure Tools.
Intel(R) Visual Fortran Package ID: w_fcompxe_2013_sp1.1.139
Intel(R) Visual Fortran Composer XE 2013 SP1 Update 1 Integration for Microsoft Visual Studio* 2013, 14.0.0074.12, Copyright (C) 2002-2013 Intel Corporation
* Other names and brands may be claimed as the property of others.
Intel® C++ Composer XE 2013 SP1 Package ID: w_ccompxe_2013_sp1.1.139
Intel® C++ Composer XE 2013 SP1 Update 1 Integration for Microsoft* Visual Studio* 2013, Version 14.0.1278.12, Copyright © 2002-2013 Intel Corporation. All rights reserved.
Microsoft Web Developer Tools 2013 2.0.40926.0
Microsoft Web Developer Tools contains the following components:
Support for creating and opening ASP.NET web projects
Browser Link: A communication channel between Visual Studio and browsers
Editor extensions for HTML, CSS, and JavaScript
Page Inspector: Inspection tool for ASP.NET web projects
Scaffolding: A framework for building and running code generators
Server Explorer extensions for Windows Azure Web Sites
Web publishing: Extensions for publishing ASP.NET web projects to hosting providers, on-premises servers, or Windows Azure
NuGet Package Manager 2.7.41101.371
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
PreEmptive Analytics Visualizer 1.2
Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
SQL Server Data Tools 12.0.30919.1
Microsoft SQL Server Data Tools
Windows Azure Mobile Services Tools 1.0
Workflow Manager Tools 1.0 1.0
This package contains the necessary Visual Studio integration components for Workflow Manager.
Sure - I have it installed into VS2008, 2010, 2012 and 2013 on the same system. The problem mentioned in the thread you linked to was fixed in Update 2 from January. Update 3 should be out later today.
The screenshot you show suggests to me that you were installing Composer XE 2013 Update 1 from 2012, not Composer XE 2013 SP1 Update 1. Yes, I know this is confusing.
P.S. since generating the error message in the attachment I have also installed VS 2012. Is it possible to get Composer XE 2013 installed with both VS2012 and VS2013 on the same machine?
I was running w_fcompxe_novsshell_2013.1.119.exe and the installation with VS2013 failed as shown. This is the version that previously installed but now will not. I do not have a license for subsequent versions, so update 2 and 3 are of no use to me.
I do not understand what you mean by "Composer XE 2013 Update 1 from 2012", what executable should I be running.
Ah, I see I should install w_fcompxe_2013-sp1.1.139.exe. Thank you Steve.
Yes, it's not immediately obvious from looking at the installer names what you have, if you don't already know about the SP1 naming. I really hope we don't do that again.... Why not install 2013-sp1.2.176 though?
"Activation rights do not allow this software to be installed. This could be due to expired subscription of incompatible serial number."
Ok - your support term expired. Fine, then use update 1.
