29487 Discussions
Connecting VC 2005 with Intel Fortran
sarma_amras
I would like to connect the VC 2005(Profession) with Intel Fortran(9.1) using the VC IDE.
May I please know how can I do this.
Kameswara Sarma
Sorry, I did not understand the question. You want to build a mixed C and Fortran application.
  • First, please download and install Service Pack 1 for Visual Studio 2005. This resolves a Microsoft bug relating to dependent projects.
  • The C code will need to be in a C++ Static Library project in your solution. Once you have that, right click on the Fortran project and select the C project to be a dependent of the Fortran project
  • Make sure that the run-time library types match between C and Fortran. In the C project, the property is under Code Generation, in Fortran, Libraries
  • I note that the Fortran program is looking for _c_fun. That suggests to me that you compiled with the /names:lowercase option. I don't recommend that - a better choice is to use !DEC$ ATTRIBUTES ALIAS to rename C_FUN or spell the C routine in upper case.
That should do it. Since you are using an old version (11.0 is current), you don't have available the samples that were added in 10.0. Those include mixed-language projects.
It should work automatically after you install the compiler. Open Visual Studio, click Help > About. Click Copy Info and then paste the contents into a reply here.
sarma_amras
Steve this is the info abt the compiler
Microsoft Visual Studio 2005
Version 8.0.50727.42 (RTM.050727-4200)
Microsoft .NET Framework
Version 2.0.50727
Installed Edition: Professional
Microsoft Visual Basic 2005 77626-235-0521391-41820
Microsoft Visual C# 2005 77626-235-0521391-41820
Microsoft Visual C++ 2005 77626-235-0521391-41820
Microsoft Visual J# 2005 77626-235-0521391-41820
Microsoft Visual Web Developer 2005 77626-235-0521391-41820
Crystal Reports AAC60-G0CSA4B-V7000AY
Crystal Reports for Visual Studio 2005
Intel Fortran Compiler Integration
Intel Fortran Compiler Integration for Microsoft Visual Studio 2005, Version 9.1.3427.2005, Copyright (C) 2002-2006 Intel Corporation
Fortran program:
program main
write(*,*)'Inside Fortran Function'
call c_fun
write(*,*)'Back to Fortran Function'
end
Cprogram:
#include
void
c_fun()
printf(
"Inside C n");
Error Message is :
error LNK2019: unresolved external symbol _c_fun referenced in function _MAIN__
Eagerly waiting for the solution and thanks in advance
Kameswara Sarma
