29281 Discussions
Convert some date to seconds since 1970
ipesenson
I need to convert different dates into seconds since 1970. There seems to be a plethora of functions to do this to today's date and time, but I need to do this for any date. So I basically need to have an inverse function of GMTIME. It seems like the function RTC would be helpful, but it again only works with current date as far as I can tell. Any hints would be greatly appreciated. Thank you very much.
-ip
pcurtis
Here are functions you need to convert any date into
a unique integer, which allows easy time interval arithmetic.
FUNCTION julian_date (yyyy, mm, dd) RESULT (julian)
IMPLICIT NONE
! converts calendar date to Julian date
! cf Fliegel & Van Flandern, CACM 11(10):657, 1968
! example: julian_date(1970,1,1)=2440588
INTEGER,INTENT(IN) :: yyyy,mm,dd
INTEGER :: julian
julian = dd-32075+1461*(yyyy+4800+(mm-14)/12)/4 + &
367*(mm-2-((mm-14)/12)*12)/12- &
3*((yyyy + 4900 + (mm - 14)/12)/100)/4
END FUNCTION julian_date
SUBROUTINE get_ymd (jd, yyyy, mm, dd)
IMPLICIT NONE
! expands a Julian date into a calendar date
INTEGER,INTENT(IN) :: jd
INTEGER,INTENT(OUT) :: yyyy,mm,dd
INTEGER :: l,n
l = jd + 68569
n = 4*l/146097
l = l - (146097*n + 3)/4
yyyy = 4000*(l + 1)/1461001
l = l - 1461*yyyy/4 + 31
mm = 80*l/2447
dd = l - 2447*mm/80
l = mm/11
mm = mm + 2 - 12*l
yyyy = 100*(n - 49) + yyyy + l
END SUBROUTINE get_ymd
