29277 Discussions
Converting CVF project to IVF: Optimization Code Error
sumitm
I am trying to convert an existing CVF Quickwin to IVF and got the following linker error
SB error: problem during multi-file optimization compilation (code 3)
Can anyone let me know how to resolve this error.
I have disabled almost all optimizations in Fortran and Linker tabs as shown attached
Thanks for your help.
Sumit
That's actually a link-time error that comes from the Intel linker shell that handles /Qipo optimization. It is invoked whether or not you are using /Qipo. Usually there is some other error message (about a missing or corrupted .lib or .obj) which appears first, and correcting that error fixes the one you saw. Changiing compiler optimization settings doesn't help.
If you're unable to solve this, please submit a test case (a zip of your converted project with output log files) to Intel Premier Support.
sumitm
Steve,
I tired to delete all obj files and rebuilt (some obj files were from CVF)
However, same problem.
Here is the log file
Can I get an idea while obj or lib file is the problem
------ Build started: Project: SB, Configuration: Debug|Win32 ------
Compiling with Intel Fortran 9.1 C:Program FilesIntelCompilerFortran9.1IA32...
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38menus.f90"
Linking...
Creating temporary file "RSP1.rsp" with contents
 /OUT:"Debug/SB.exe" /INCREMENTAL:NO /NOLOGO /NODEFAULTLIB:"dfconsol.lib" /NODEFAULTLIB:"libc.lib" /NODEFAULTLIB:"libcmt.lib" /DEBUG /PDB:"Debug/SBO48_38.pdb" /SUBSYSTEM:WINDOWS /OPT:NOWIN98 /ENTRY:"WinMainCRTStartup" kernel32.lib /MACHINE:I386
 /NODEFAULTLIB:"libifcoremt.lib"  "Debug/Str_Stn_Module.obj" "Debug/module_waveabs.obj" "Debug/module_opcb.obj" "Debug/module_common.obj" "Debug/Module_Bottle3D.obj" "Debug/dizzy.obj" "Debug/module_power.obj" "Debug/module_inputinfo.obj" "Debug/module_x2def.obj" "Debug/module_pieval.obj" "Debug/module_color.obj" "Debug/AVIS2D.obj" "Debug/aiimwin32_glo_qnch.obj" "Debug/opengl_Globals.obj" "Debug/DLLPRGRS.obj" "Debug/ADOBJS.obj" "Debug/ANIMFOR.obj" "Debug/opengl_pref.obj" "Debug/avisgrid.obj" "Debug/EXCEL97A.obj" "Debug/display_string.obj" "Debug/ANIMWIN32GLOBALS.obj" "Debug/module_copyfolder.obj" "Debug/animfor_qnch.obj" "Debug/AVIEWER_new.obj" "Debug/ViewBot_B.obj" "Debug/Read_dxf.obj" "Debug/optimize_process.obj" "Debug/menus.obj" "Debug/HB13_15.obj" "Debug/read_pref_dxf.obj" "Debug/Inpbot.obj" "Debug/savepower.obj" "Debug/ovenc.obj" "Debug/HB4_6.obj" "Debug/design_optimization.obj" "Debug/refresh.obj" "Debug/Preform_Dgn_HS.obj" "Debug/HB34_36.obj" "Debug/animwin32_qnch.obj" "Debug/READCHS.obj" "Debug/HB25_27.obj" "Debug/bottlesubs.obj" "Debug/sav_pow_pr.obj" "Debug/bmtempf.obj" "Debug/subrs.obj" "Debug/plotir.obj" "Debug/loadhts.obj" "Debug/HB10_12.obj" "Debug/multicavity.obj" "Debug/INP_POWER.obj" "Debug/readbot.obj" "Debug/Heatpro.obj" "Debug/HB40_42.obj" "Debug/comdlgerr.obj" "Debug/Readprefm.obj" "Debug/parameter.obj" "Debug/HB31_33.obj" "Debug/calcnF.obj" "Debug/ANIMWIN32.obj" "Debug/PTIGRAPHICS.obj" "Debug/HB22_24.obj" "Debug/bottlegraphs.obj" "Debug/AUTODICE.obj" "Debug/all_control.obj" "Debug/ViewPref.obj" "Debug/Modify_preform.obj" "Debug/HB16_18.obj" "Debug/str_stn_pet.obj" "Debug/InpIRF.obj" "Debug/sbo40heater.obj" "Debug/prefconf.obj" "Debug/HB7_9.obj" "Debug/3Dtemp.obj" "Debug/HB37_39.obj" "Debug/calorimetry.obj" "Debug/background.obj" "Debug/readpower.obj" "Debug/HB28_30.obj" "Debug/calcn.obj" "Debug/petwall.obj" "Debug/HB19_21.obj" "Debug/botconfig.obj" "Debug/heater.res" "C:Program FilesMicrosoft Visual Studio .NET 2003XFTXFT8XFT.lib" "C:IVFf90gllibf90GL.lib" "C:IVFf90gllibglut32.lib" "C:IVFf90gllibf90GLU.lib" "C:IVF9V9SamplesQuickWinScigraphDebugScigraph.lib" "C:IVFf90gllibf90GLUT.lib"
Creating command line "Link @"c:Ivf_sbDebugRSP1.rsp""
backend signals
Severe: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
Link: error: problem during multi-file optimization compilation (code
 3)
Link: error: problem during multi-file optimization compilation (code 3)
SBO48_38 build failed.
Looks as if you've found a bug in the pre-linker. Please submit a support request to Intel Premier Support and attach a ZIP of your project.
I would recommend removing all the /nodefaultlib linker options - they are rarely necessary and cover up other errors.
sumitm
Thanks Steve,
Unfortunately, Premier has had this project for a couple of months. I did not get any response so I am trying on my own again. It is not a simple project. Has array visualizer and opengl in it. Ron advised me to run with CAV instead of IAV in Intel VF 9.1. So thats all I have changed.
After I removed all /nodefaultlib inker options, this is what I get.
Does that point to something.
Sumit
------ Build started: Project: SBO48_38, Configuration: Debug|Win32 ------
Deleting intermediate files and output files for project 'SBO48_38', configuration 'Debug|Win32'.
Compiling resources...
Rc /d "_DEBUG" /l 0x0409 /fo "Debug/heater.res"  "c:Ivf_sbo48_38heater.rc"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38Str_Stn_Module.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_waveabs.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_opcb.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_common.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38Module_Bottle3D.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38dizzy.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_power.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_inputinfo.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_x2def.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_pieval.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_color.f90"
ifort /nologo
/Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38AVIS2D.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38aiimwin32_glo_qnch.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38opengl_Globals.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38DLLPRGRS.F90"
c:Ivf_sbo48_38DLLPRGRS.F90(134) : Warning: The data type of the actual argument does not match the definition.
		    lret = EnableWindow( hwndParent, .FALSE. )
c:Ivf_sbo48_38DLLPRGRS.F90(256) : Warning: The data type of the actual argument does not match the definition.
	    lret = EnableWindow( context % hwndParent, .TRUE. )
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ADOBJS.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ANIMFOR.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38opengl_pref.f90"
c:Ivf_sbo48_38opengl_pref.f90(1729) : Warning: The data type of the actual argument does not match the definition.
	  .FALSE.,			&	! Italic
c:Ivf_sbo48_38opengl_pref.f90(1730) : Warning: The data type of the actual argument does not match the definition.
	  .FALSE.,			&	! Underline
c:Ivf_sbo48_38opengl_pref.f90(1731) : Warning: The data type of the actual argument does not match the definition.
	  .FALSE.,			&	! Strikeout
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38avisgrid.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38EXCEL97A.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38display_string.f90"
c:Ivf_sbo48_38display_string.f90(137) : Warning: The data type of the actual argument does not match the definition.
c:Ivf_sbo48_38display_string.f90(255) : Warning: The data type of the actual argument does not match the definition.
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ANIMWIN32GLOBALS.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38module_copyfolder.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38animfor_qnch.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "C:IVF_SBO48_38AVIEWER_new.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ViewBot_B.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38Read_dxf.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38optimize_process.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB13_15.F90"
ead_pref_dxf.f90"
c:Ivf_sbo48_38
ead_pref_dxf.f90(1011) : Warning: The data type of the actual argument does not match the definition.   [INT2]
itemp=RGB(int2(255*ContourColours(vertex1,3)),int2(255*ContourColours(vertex1,4)),int2(255*ContourColours(vertex1,5)))
c:Ivf_sbo48_38
c:Ivf_sbo48_38
c:Ivf_sbo48_38
ead_pref_dxf.f90(1869) : Warning: The data type of the actual argument does not match the definition.   [INT2]
c:Ivf_sbo48_38
c:Ivf_sbo48_38
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38Inpbot.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38savepower.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ovenc.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB4_6.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38design_optimization.f90"
efresh.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38Preform_Dgn_HS.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB34_36.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38animwin32_qnch.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38READCHS.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB25_27.F90"
:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ottlesubs.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38sav_pow_pr.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38mtempf.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38subrs.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38plotir.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38loadhts.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB10_12.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38multicavity.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38INP_POWER.F90"
eadbot.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38Heatpro.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB40_42.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38comdlgerr.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38Readprefm.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38parameter.f90"
/module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB31_33.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38calcnF.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ANIMWIN32.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38PTIGRAPHICS.F90"
c:Ivf_sbo48_38PTIGRAPHICS.F90(137) : Warning: The data type of the actual argument does not match the definition.
    status = SETWINDOW( .TRUE.,DBLE(xl), DBLE(yl), DBLE(xh), DBLE(yh))
c:Ivf_sbo48_38PTIGRAPHICS.F90(937) : Warning: The data type of the actual argument does not match the definition.
	  if (filled.eq.1) retv=POLYGON_W($GFILLINTERIOR,points,2*L)
c:Ivf_sbo48_38PTIGRAPHICS.F90(938) : Warning: The data type of the actual argument does not match the definition.
      if (filled.eq.0) retv=POLYGON_W($GBORDER,points,2*L)
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB22_24.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ottlegraphs.f90"
c:Ivf_sbo48_38ottlegraphs.f90(833) : Warning: The data type of the actual argument does not match the definition.   [INT2]
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38AUTODICE.F90"
c:Ivf_sbo48_38AUTODICE.F90(45) : Warning: The data type of the actual argument does not match the definition.
      CALL $Application_SetVisible(excelapp, .TRUE.)
c:Ivf_sbo48_38AUTODICE.F90(218) : Warning: The data type of the actual argument does not m
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38all_control.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ViewPref.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38Modify_preform.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB16_18.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38str_stn_pet.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38InpIRF.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38sbo40heater.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38prefconf.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB7_9.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_383Dtemp.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB37_39.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38calorimetry.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38ackground.f90"
c:Ivf_sbo48_38ackground.f90(691) : Warning: The data type of the actual argument does not match the definition.   [INT2]
eadpower.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB28_30.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38calcn.f90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38petwall.f90"
c:Ivf_sbo48_38petwall.f90(1003) : Warning: The data type of the actual argument does not match the definition.   [INT2]
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38HB19_21.F90"
ifort /nologo /Zi /Od /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c  /Qvc7.1 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio .NET 2003Vc7in" "c:Ivf_sbo48_38otconfig.f90"
Linking...
 /OUT:"Debug/SBO48_38.exe" /INCREMENTAL:NO /NOLOGO /DEBUG /PDB:"Debug/SBO48_38.pdb" /SUBSYSTEM:WINDOWS /OPT:NOWIN98 /ENTRY:"WinMainCRTStartup" kernel32.lib /MACHINE:I386
Creating command line "Link @"c:Ivf_sbo48_38DebugRSP1.rsp""
backend signals
What's the Premier Support issue number? I'll find out what is going on (Monday).
sumitm
Steve,
Thanks for following up.
The issue number is 379265
Sumit
sumitm
Steve,
Were you able to get an update from Premier.
Sumit
I asked the engineer who is helping you (Ron) to get back to you - normally he's very good at this, so I don't know what happened. I'll try to get ahold of him again on Monday. Sorry for the delay.
