In Principle I have a C++ code, which fills up a dynamic list (FIL_lst), running in a thread.
In another Fortran thread I'm waiting and processing the FIL_list, however, for example the parameter processed is set to 0 in C++ but readed out with in the fortran code with processed = 892614965. I pass the FilList by reference to the C++ program. Does anyon know what's the reason for this problem ? The other arguments of FIL_it are passed correctly.
C++ definitions:
struct FIL_it{ // File item
char fname[TYP_FILEN]; // the file-name
int processed; // 0.. not processed, 1.. processed
struct FIL_it *next; // next item
struct FIL_it *prev; // previous item
struct FIL_lst{
struct FIL_it *list_top; // top of file list
struct FIL_it *list_bot; // bottom of file list (last item inserted)
int locked; // 0.. list free, 1.. list locked (by another process)
int nFiles; // number of files in list
extern FIL_lst *FilList;
Fortran definitions:
integer,parameter:: TYP_PN = 64
integer,parameter:: TYP_IS = 4
type FIL_it
character(TYP_PN) fname
integer(TYP_IS) processed ! 1.. file was already processed, 0.. file was not processed yet
type(FIL_it), pointer:: next
type(FIL_it), pointer:: prev
end type
type FIL_lst
type(FIL_it),pointer:: list_top
type(FIL_it),pointer:: list_bot
integer(TYP_IS) locked ! 0.. list free, 1.. list locked (by another process)
integer(TYP_IS) nFiles ! number of files in list
end type
type(FIL_lst),pointer:: FilList;
链接已复制
Have you checked the alignment of data in your structure? It may be that your C++ uses 8-byte alignment ( #pragma pack(8);structure components are aligned on 8-byte boundaries) and Fortran's default setting is 1-byte alignment (structure components are "packed"). Try the following:
Add a metadirective to your TYPE definitions.
!DEC$ ATTRIBUTES ALIGN: 8 :: FIL_it,FIL_lst
Also, I think it advisable to make sure that your TYPE's components are ordered in memory as defined (use SEQUENCE). For example:
type FIL_it
SEQUENCE
end type
Let us know, if this cures your problem.
Joerg Kuthe
www.qtsoftware.com
