- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Good day,
In the main subroutine is declared a matrix size of 500 times 500. This matrix is transferred to the subroutine Set_null. In the subroutine Set_null I want another matrix (matrix_work) of the same size (a_matrix), but the program crashes. I have simplified the example to a minimum so that the problem still existed (see figures).
If you make the same thing, but for matrix 300 by 300 everything is OK (MAX_SIZE = 300).
If you use matrix_work allocatable everything is OK.
Intel Fortran Compiler 11.1.067.
Best regards
Lukas Weis
[fortran]
! Experiment6 - Padani.
subroutine Experiment6
implicit none
integer(4), parameter :: MAX_SIZE = 500
real(8), dimension(MAX_SIZE, MAX_SIZE):: a_matrix
call Set_null(a_matrix(1:MAX_SIZE, 1:MAX_SIZE))
return
contains
! Nulovani matice.
pure subroutine Set_null(matrix)
implicit none
real(8), intent(inout), dimension(:,:) :: matrix
real(8), dimension(size(matrix, dim=1), size(matrix, dim=2)) :: matrix_work
matrix = 0.d0
matrix_work = 0.d0
return
end subroutine
end subroutine Experiment6
[/fortran]
- Balises:
- Intel® Fortran Compiler
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Stack overflow. Easy fix is to set the property Fortran > Optimization > Heap Arrays to 0. (I think that was in 11.1.) Or add /heap-arrays to the options list. Other choice is to set the Linker > System > Stack Reserve size to some larger value, say, 100000000. (Don't go above that unless you need to.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Steve,
I am surprised that this is a stack overflow problem, as the matrices are 500 x 500 x 8 = 2mb. Given there are 2 matrices and a possible copy for the array sections, that's only 6mb, which is not a big demand on the stack. I suspect there could be other heavy demands for exercises 1-5 ?
The more robust solution would be to make these arrays allocatable, or place them in a module or a common block.
Could I suggest that the Stack Reserve size selection is a bit unfriendly. Any consideration to supporting 100m or 100mb instead of 100000000.
John
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
@Lukas
Maybe your stack allocation crossed boundary of guard pages?When you inspect raw stack data specific pattern(I do not remeber which exactly) will be overwritten by your matrix allocation.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The default stack size is set by the linker (a utility provided by MS with VC/WSDK) to 1 Mb.
The linker accepts a stack size specification in decimal or hex. Thus, /stack:0x7000000 would provide over 100 Mb of stack.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I caution against that. Lukas is on a 32-bit system (at least the application is 32-bit). Assuming he gets the single threaded version to work with 100mb stack. If he then options to go multi-threaded, say on a 4 core with HT system (not unreasonable), then this would require 800MB of RAM (possibly 900MB if there is an additional monitor tread created). The best route is to use heap arrays or do the allocation.
Jim Dempsey
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Jim, my reading of John Campbell's post suggested a slightly different reason for his request. Rather than requesting a new (and large) default stack size, he asked for the suffix 'mb' or 'Mb' to be allowed, so that he could write /stack:100MB instead of the longer /stack:100000000.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
This is an MS linker option, we have no control over it.
The routine set_null declares an automatic array matrix_work - this is put on the stack by default. It could also make sense to declare this ALLOCATABLE and allocate it to the desired size. I prefer this to changing the stack size. It will get automatically deallocated on routine exit.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The stack size allocation is not just 1mb, as the following examples show.
I tested the following examples on XE 2011 IA-32 and did not get a stack overflow for the first example, but did for the second. There must be some recognition of the stack requirement for local arrays that are explicitly sized.
As much is practical, I always avoid the use of stack for temporary arrays, certainly those larger than 20 kbytes. Stack overflow errors should be avoided, rather than changing the stack size. As Jim indicates, this becomes much more important for OpenMP when replicating private arrays.
[fortran]
call Experiment6 ! this example works with no stack overflow
end
implicit none
real(8), dimension(MAX_SIZE, MAX_SIZE) :: a_matrix
write (*,*) 'size_of a_matrix =', sizeof (a_matrix),' bytes'
call Set_null (a_matrix(1:MAX_SIZE, 1:MAX_SIZE))
return
contains
! Nulovani matice.
! pure subroutine Set_null(matrix)
implicit none
matrix = 0.d0
matrix_work = 0.d0
write (*,*) 'size_of matrix_work =', sizeof (matrix_work),' bytes'
return
end subroutine
end subroutine Experiment6[/fortran]
The following example fails at max_size = 400, indicating that a smaller default stack size has been allocated, probably about 2mb in size.
[fortran]
do MAX_SIZE = 100,1000,100
call Experiment6 (MAX_SIZE)
end do
end
subroutine Experiment6 (MAX_SIZE)
implicit none
integer(4) :: MAX_SIZE
write (*,*) ' '
write (*,*) 'Testing for MAX_SIZE =',max_size
return
contains
! Nulovani matice.
implicit none
matrix = 0.d0
matrix_work = 0.d0
return
end subroutine
John
ps: can we have a paste option that does not produce double lines for fortran code ?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
FWIW, I compose my responses in Word, paste code into Word first with a font setting of Courier New, and then add it to the forum comment section using "Paste from Word" option. This works better for me, but YMMV.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
[fortran]
subroutine GetintsDlg(imes,imax,ivals,nval)
implicit none
! imax = max number of ints that can be returned
! itmp = array of integer returned
! nval = number of integers returned
integer, intent(in) :: imax, imes
integer, intent(out) :: nval
integer, intent(out) :: ivals(imax)
integer(DWORD) :: ret
[/fortran]
Just trying that paste from word tip, which seems to work for me despite the fact it looks all wrong prior to hitting the submit button. Thanks for the tip the code format thing really bugs me.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Use the Code button which is rightmost in the toolbar. Select Fortran as the language. No double spacing.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
If you past from Linux gedit this works (no double space).
Paste from MS VS doesn't work
Paste from MS VS to MS NotePad, then Paste from NotePad (gets double space)
Jim Dempsey
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I paste from VS all the time. In fact I just did it in another thread.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Another reason I use Word is because then I've a locally saved copy of my topic/comments in case something wrong during posting on the forum site (which is a little too frequent for me in my work environment: IE8 (!) and poor extranet connectivity).
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
In my last attempt, I went back and forth between linux and Windows, but ended up waiting a few hours until the file attach became successful.
I suppose the ability to paste may vary among browsers, with IE presumably having superior compatibility with Microsoft applications.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Pasting code from VS or Notepad always creates a mess for me. I am normally using chrome BTW. This suggests that success is dependant on a number of factors....
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
VS copy and paste directly inline (not code button paste)
IF (IOPT .EQ. 1) THEN
!$OMP PARALLEL DO
!DIR$ VECTOR ALIGNED
DO 10 I=1,N
A(I)=DCONJG(A(I))
10 CONTINUE
END IF
C
VS copy and paste into code button
IF (IOPT .EQ. 1) THEN !$OMP PARALLEL DO !DIR$ VECTOR ALIGNED DO 10 I=1,N A(I)=DCONJG(A(I)) 10 CONTINUE END IF C
Jim
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I know copy and paste inline doesn't work. The code button does.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
It worked that time.
VS C++ copy and paste into code window:
long SerialFib2( long n ) { if( n<2 ) return n; long fib0 = 1; // most recent long fib1 = 1; // 1 prior to most recent long fib2 = 0; // 2 prior to most recent long i; for(i=2; i<n; ++i) { fib2 = fib1; fib1 = fib0; fib0 = fib1 + fib2; } return fib0; }
Jim
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
It is a mystery to me. Usually when I have something I really want in a post, it gets bunged up. Next a VC C++ copy followed by "paste from Word"
if( n<2 )
return n;
long i;
for(i=2; i<n; ++i)
fib2 = fib1;
fib1 = fib0;
fib0 = fib1 + fib2;
return fib0;
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
