Crashing of the program (matrix 500 x 500)
Lukas_W_
初學者
3,819 檢視
Good day,
In the main subroutine is declared a matrix size of 500 times 500. This matrix is transferred to the subroutine Set_null. In the subroutine Set_null I want another matrix (matrix_work) of the same size (a_matrix), but the program crashes. I have simplified the example to a minimum so that the problem still existed (see figures).
If you make
the same thing, but for matrix 300 by 300 everything is OK (
MAX_SIZE = 300).
If you use matrix_work allocatable everything is OK.
Intel Fortran Compiler 11.1.067.
Best regards
Lukas Weis
[fortran]
  ! Experiment6 - Padani.
  subroutine Experiment6
    implicit none
    integer(4), parameter ::                  MAX_SIZE = 500
    real(8), dimension(MAX_SIZE, MAX_SIZE)::  a_matrix
      call Set_null(a_matrix(1:MAX_SIZE, 1:MAX_SIZE))
    return
  contains
    ! Nulovani matice.
    pure subroutine Set_null(matrix)
      implicit none
      real(8), intent(inout), dimension(:,:) ::                        matrix
      real(8), dimension(size(matrix, dim=1), size(matrix, dim=2)) ::  matrix_work
      matrix = 0.d0
      matrix_work = 0.d0
      return
    end subroutine
  end subroutine Experiment6
[/fortran]
0 積分
27 回應
Steven_L_Intel1
2,922 檢視
Stack overflow. Easy fix is to set the property Fortran > Optimization > Heap Arrays to 0. (I think that was in 11.1.) Or add /heap-arrays to the options list. Other choice is to set the Linker > System > Stack Reserve size to some larger value, say, 100000000. (Don't go above that unless you need to.
See Doctor Fortran - Don't Blow Your Stack!
John_Campbell
新貢獻者 II
2,922 檢視
Steve,
I am surprised that this is a stack overflow problem, as the matrices are 500 x 500 x 8 = 2mb. Given there are 2 matrices and a possible copy for the array sections, that's only 6mb, which is not a big demand on the stack.  I suspect there could be other heavy demands for exercises 1-5 ?
The more robust solution would be to make these arrays allocatable, or place them in a module or a common block.
Could I suggest that the Stack Reserve size selection is a bit unfriendly. Any consideration to supporting 100m or 100mb instead of 100000000.
John
Bernard
傑出貢獻者 I
2,922 檢視
@Lukas
Maybe your stack allocation crossed boundary of guard pages?When you inspect raw stack data specific pattern(I do not remeber which exactly) will be overwritten by your matrix allocation.
mecej4
榮譽貢獻者 III
2,922 檢視
The default stack size is set by the linker (a utility provided by MS with VC/WSDK) to 1 Mb.
The linker accepts a stack size specification in decimal or hex. Thus, /stack:0x7000000 would provide over 100 Mb of stack.
jimdempseyatthecove
榮譽貢獻者 III
2,922 檢視
I caution against that. Lukas is on a 32-bit system (at least the application is 32-bit). Assuming he gets the single threaded version to work with 100mb stack. If he then options to go multi-threaded, say on a 4 core with HT system (not unreasonable), then this would require 800MB of RAM (possibly 900MB if there is an additional monitor tread created). The best route is to use heap arrays or do the allocation.
Jim Dempsey
mecej4
榮譽貢獻者 III
2,922 檢視
Jim, my reading of John Campbell's post suggested a slightly different reason for his request. Rather than requesting a new (and large) default stack size, he asked for the suffix 'mb' or 'Mb' to be allowed, so that he could write /stack:100MB instead of the longer /stack:100000000.
Steven_L_Intel1
2,922 檢視
This is an MS linker option, we have no control over it.
The routine set_null declares an automatic array matrix_work - this is put on the stack by default. It could also make sense to declare this ALLOCATABLE and allocate it to the desired size. I prefer this to changing the stack size. It will get automatically deallocated on routine exit.
John_Campbell
新貢獻者 II
2,922 檢視
The stack size allocation is not just 1mb, as the following examples show.
I tested the following examples on XE 2011 IA-32 and did not get a stack overflow for the first example, but did for the second. There must be some recognition of the stack requirement for local arrays that are explicitly sized.
As much is practical, I always avoid the use of stack for temporary arrays, certainly those larger than 20 kbytes.  Stack overflow errors should be avoided, rather than changing the stack size. As Jim indicates, this becomes much more important for OpenMP when replicating private arrays.
[fortran]
      call Experiment6    !  this example works with no stack overflow
      end
      implicit none
      real(8), dimension(MAX_SIZE, MAX_SIZE) :: a_matrix
      write (*,*) 'size_of a_matrix =', sizeof (a_matrix),' bytes'
      call Set_null (a_matrix(1:MAX_SIZE, 1:MAX_SIZE))
      return
      contains
         ! Nulovani matice.
!        pure subroutine Set_null(matrix)
         implicit none
         matrix = 0.d0
         matrix_work = 0.d0
         write (*,*) 'size_of matrix_work =', sizeof (matrix_work),' bytes'
         return
         end subroutine
      end subroutine Experiment6[/fortran]
The following example fails at max_size = 400, indicating that a smaller default stack size has been allocated, probably about 2mb in size.
[fortran]
      do MAX_SIZE = 100,1000,100
         call Experiment6 (MAX_SIZE)
      end do
      end
      subroutine Experiment6 (MAX_SIZE)
      implicit none
      integer(4)                             :: MAX_SIZE
      write (*,*) ' '
      write (*,*) 'Testing for MAX_SIZE =',max_size
      return
      contains
         ! Nulovani matice.
         implicit none
         matrix = 0.d0
         matrix_work = 0.d0
         return
         end subroutine
John
ps: can we have a paste option that does not produce double lines for fortran code ?
FortranFan
榮譽貢獻者 III
2,922 檢視
FWIW, I compose my responses in Word, paste code into Word first with a font setting of Courier New, and then add it to the forum comment section using "Paste from Word" option.  This works better for me, but YMMV.
andrew_4619
榮譽貢獻者 III
2,922 檢視
[fortran]
subroutine GetintsDlg(imes,imax,ivals,nval)
        implicit none
        ! imax = max number of ints that can be returned
        ! itmp = array of integer returned
        ! nval = number of integers returned
        integer, intent(in)  :: imax, imes
        integer, intent(out) :: nval
        integer, intent(out) :: ivals(imax)
        integer(DWORD)       :: ret
[/fortran]
Just trying that paste from word tip, which seems to work for me despite the fact it looks all wrong prior to hitting the submit button. Thanks for the tip the code format thing really bugs me.
Steven_L_Intel1
2,922 檢視
Use the Code button which is rightmost in the toolbar. Select Fortran as the language. No double spacing.
jimdempseyatthecove
榮譽貢獻者 III
2,922 檢視
If you past from Linux gedit this works (no double space).
Paste from MS VS doesn't work
Paste from MS VS to MS NotePad, then Paste from NotePad (gets double space)
Jim Dempsey
Steven_L_Intel1
2,922 檢視
I paste from VS all the time. In fact I just did it in another thread.
FortranFan
榮譽貢獻者 III
2,922 檢視
Another reason I use Word is because then I've a locally saved copy of my topic/comments in case something wrong during posting on the forum site (which is a little too frequent for me in my work environment: IE8 (!) and poor extranet connectivity).
TimP
榮譽貢獻者 III
2,922 檢視
In my last attempt, I went back and forth between linux and Windows, but ended up waiting a few hours until the file attach became successful.
I suppose the ability to paste may vary among browsers, with IE presumably having superior compatibility with Microsoft applications.
andrew_4619
榮譽貢獻者 III
2,922 檢視
Pasting code from VS or Notepad always creates a mess for me. I am normally using chrome BTW. This suggests that success is dependant on a number of factors....
jimdempseyatthecove
榮譽貢獻者 III
2,922 檢視
VS copy and paste directly inline (not code button paste)
IF (IOPT .EQ. 1) THEN
!$OMP PARALLEL DO
!DIR$ VECTOR ALIGNED
DO 10 I=1,N
A(I)=DCONJG(A(I))
10 CONTINUE
END IF
C
VS copy and paste into code button
!$OMP PARALLEL DO
        DO 10 I=1,N
          A(I)=DCONJG(A(I))
   10   CONTINUE
      END IF
C
Jim
Steven_L_Intel1
2,922 檢視
I know copy and paste inline doesn't work. The code button does.
jimdempseyatthecove
榮譽貢獻者 III
2,922 檢視
It worked that time.
VS C++ copy and paste into code window:
long SerialFib2( long n )
 if( n<2 )
  return n;
 long fib0 = 1; // most recent
 long fib1 = 1; // 1 prior to most recent
 long fib2 = 0; // 2 prior to most recent
 long i;
 for(i=2; i<n; ++i)
  fib2 = fib1;
  fib1 = fib0;
  fib0 = fib1 + fib2;
 return fib0;
Jim
jimdempseyatthecove
榮譽貢獻者 III
2,823 檢視
It is a mystery to me. Usually when I have something I really want in a post, it gets bunged up. Next a VC C++ copy followed by "paste from Word"
if( n<2 )
return n;
long i;
for(i=2; i<n; ++i)
fib2 = fib1;
fib1 = fib0;
fib0 = fib1 + fib2;
return fib0;
回覆
