Create new .f90 file in macOS
Ortega__David
I'm trying to run Intel Fortran Compiler for macOS Mojave 10.14. I have installed the package, but I'm not able to create new files. In order to run the compiler, I write in the terminal:
source /opt/intel/bin/compilervars.sh intel64
then,
ifort my_source_file.f90
The terminal says 'file not found', when all I'm trying to do is create that file.
How does one create a file in IFort?
Thanks!
Juergen_R_R
Valued Contributor II
Hi David, usually you take your favorite editor, type in the file, and save it, thereby creating the file. You can also use an IDE where others are better suited to give you advice.
Best, Juergen
Steve_Lionel
The ifort command is used to compile the Fortran source once you have created it.
ta__thu
where do you save the file?
As in like in a note pad? Sorry I am new to this! Thank you
