HI, I AM MAKING A PROGRAM IN WIN32, BUT NOW I AM STOPPED, I WAS TRYING TO DISABLE/ENABLE SOME CONTROLS IN A MODELESS DIALOG BOX, BUT I CAN ONLY DISABLE/ENABLE THE EDIT BOX CONTROLS, SO I CAN'T DISABLE/ENABLE RADIO BUTTONS ANDCOMBO BOX AND TEX BOX CONTROLS, I PASTEMY DIALOG PROCEDURE, WHERE I CALL SenddlgitemMessage MESSAGE TO DISABLE THE CONTROLS. PLEASE HELP!:
integer(4) function TendonDataDlgProc( hDlg, message, wParam, lParam )
! Processes messages for "TendonData" dialog box
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_TendonDataDlgProc@16' :: TendonDataDlgProc
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'TendonDataDlgProc' :: TendonDataDlgProc
!DEC$ ENDIF
use comctl32
use dfwina
use Globals
implicit none
integer hDlg ! window handle of the dialog box
integer message ! type of message
integer wParam ! message-specific information
integer lParam
!DECLARES HANDLES TO THE CONTROLS
!DECLARA HANDLES PARA LOS CONTROLES
integer(4) HDA
integer(4) HJF1
integer(4) HJF2
integer(4) HFE
integer(4) HSE
integer(4) HBE
integer(4) HPF
integer(4) HTIME
integer(4) HJACK
integer(4) HTDA
integer(4) HTJF1
integer(4) HTJF2
integer(4) HTFE
integer(4) HTSE
integer(4) HTBE
integer(4) HTPF
include 'resource.fd'
! Variables
integer(4) iret
logical(4) result, bret
character(80) text
type (T_INITCOMMONCONTROLSEX) iccex
!GETS HANDLES TO THE CONTROLS(NOW I DON'T USE THEM)
hDA = GetDlgItem(hDlg,IDC_DA)
hJF1 = GetDlgItem(hDlg,IDC_JF1)
hJF2 = GetDlgItem(hDlg,IDC_JF2)
hFE= GetDlgItem(hDlg,IDC_FE)
hSE= GetDlgItem(hDlg,IDSE)
hBE = GetDlgItem(hDlg,IDC_BE)
hTIME = GetDlgItem(hDlg,IDC_TIME)
HPF= GetDlgItem(hDlg,IDC_PF)
hJACK = GetDlgItem(hDlg,IDC_JACK)
hTDA = GetDlgItem(hDlg,IDC_TDA)
hTJF1 = GetDlgItem(hDlg,IDC_TJF1)
hTJF2 = GetDlgItem(hDlg,IDC_TJF2)
HTPF= GetDlgItem(hDlg,IDC_TPF)
select case (message)
case (WM_INITDIALOG)
TendonDataDlgProc = 1
return
case (WM_COMMAND) ! message: received a command
!ENABLE/DISABLE CONTROLS WHEN I PRESSA RADIO BUTTON
if (LoWord(wParam) .EQ. IDC_pre1) then
!THESE WORKS(EDIT BOX CONTROLS)
iret = SendDlgItemMessage(hdlg,idc_da,WM_ENABLE,.FALSE.,0)
; iret = SendDlgitemMessage(hdlg,idc_jf1,WM_ENABLE,.FALSE.,0)
!THESE DOESNT WORKS, (RADIO BUTTONS, COMBO BOX AND TEXT BOX CONTROLS)
iret = SendDlgItemMessage(hdlg,idc_tda,WM_ENABLE,.FALSE.,0)
iret = SendDlgitemMessage(hdlg,idc_tjf1,WM_ENABLE,.FALSE.,0)
iret = SendDlgItemMessage(hdlg,idSE,WM_ENABLE,.FALSE.,0)
iret = SendDlgitemMessage(hdlg,idc_BE,WM_ENABLE,.FALSE.,0)
return
end if
if (LoWord(wParam) .EQ. IDC_post1) then
!WORKS
iret = SenddlgitemMessage(hdlg,idc_DA,WM_ENABLE,.TRUE.,0)
iret = SenddlgitemMessage(hdlg,idc_JF1,WM_ENABLE,.TRUE.,0)
!DOESNT WORKS
iret = SenddlgitemMessage(hdlg,idc_tDA,WM_ENABLE,.TRUE.,0)
iret = SenddlgitemMessage(hdlg,idc_tJF1,WM_ENABLE,.TRUE.,0)
iret = SenddlgitemMessage(hdlg,idSE,WM_ENABLE,.TRUE.,0)
iret = SenddlgitemMessage(hdlg,idc_BE,WM_ENABLE,.TRUE.,0)
return
end if
if (LoWord(wParam) == IDOK) then
! Exit the dialog
iret = DestroyWindow (hdlg)
ghDlgModeless = 0
return
end if
end select
TendonDataDlgProc = 0 ! Didn't process the message
return
end
iret = EnableWindow(GetDlgItem(hDlg, IDC_XX), TRUE/FALSE)
A couple of remarks:
- You should use TRUE and FALSE (integer constants declared in IFWIN) rather than logical .TRUE. and .FALSE. as arguments to Win32 functions. While the latter will almost certainly work, it's better to be safe than sorry.
- Please don't type in ALL CAPS. It is considered rude in the internet.
