29286 Discussions
ifort 9.0: undef reference "__ctype_b"
fuchs
Hi everyone,
I get linker errors like:
tecxxx.cpp:(.text+0xe7): undefined reference to `__ctype_b'
when I compile&link a small fortran code `test.f':
program test; call tecini; end
against tecio.a (renamed to libtecio.a):
ifort test.f -ltecio
on my system (Debian, libc6_2.3.5-6, ifort 9.0, tecplot 10)
Obviously I cannot modify the tecplot library.
What can I do ? Is there a workaround ? Maybe a simple wrapper __ctype_b -> __ctype_b_loc ?
Christian
TimP
This has nothing to do with ifort. Your outdated libtecio.a requires an old version of C library support. glibc 2.3 made an incompatible change in "string.h". If someone decided that long ago to commit to this commercial package, they might have considered the perpetual license.
ronaldo_alves
Hi tim,
I got the same error. Actually the complete error was:
$ ifc -o teste1 teste1.f90
program TESTE
5 Lines Compiled
/opt/intel/compiler70/ia32/lib/libIEPCF90.a(f90file.o)(.text+0x4746): In function 'FileOpen':
: undefined reference to 'errno'
/opt/intel/compiler70/ia32/lib/libIEPCF90.a(f90fioerr.o)(.text+0x4d3): In function 'f_f77ioerr':
/opt/intel/compiler70/ia32/lib/libIEPCF90.a(f90fioerr.o)(.text+0x6d9): In function 'f_fiomess.':
/opt/intel/compiler70/ia32/lib/libIEPCF90.a(f90fioerr.o)(.text+0x76b): In function 'f_seterrno':
The program teste1.f90 consists of:
program teste
x = 1
y = 2 + x
write(*,*)
end program teste
I read about the old C libraries, but I didn't understand it well. How do I identify the obsolete libraries? For which ones shall I replace?
Ronaldo
UFRJ-Brazil.
TimP
This is not necessarily related to the problem of the previous posts. If you have updated your glibc (perhaps as a consequence of updating linux) since you installed ifc 7.x, you could try removing the ifc installation and repeating it. If you are trying to use ifc 7.x with a newer version of linux, you may have to figure out yourself which glibc library satisfies the errno reference, and add it to the link line e.g.
if
nm libsomething.a | grep errno
or
cat libsomething.so |grep erron
shows that libsomething contains errno,
add
-lsomething
to your command line.
gcc -print-search-dirs
would show the library search paths which you should consider.
This may be among the reasons why currently supported ifort versions check the gcc library paths at compile time.
andrewritzmann
Hi Christian,
You might consider downloading the source for tecio from the following location and compiling it with your version of gcc. This should resolve any issues with incompatible types.
http://download.tecplottalk.com/tecio/
Andrew
Note that this thread is more than three and a half years old.
