29362 Discussions
DLL error LNK1561: Entry point mus be defined
Zambrano-Cruzatty__L
Hello there,
I have a Fortran code that is going to be used as a User-defined DLL subroutine in another executable. I'm using the following set up in the configuration manager:
 SuppressStartupBanner="true" (’General’ Section)
 ReentrantCode="reentrancyThreaded" (’Code Generation’ Section)
 SourceFileFormat= Use Free Format
 RealKIND="realKIND8" (’Data’ Section)
 LocalVariableStorage="localStorageAutomatic" (’Data’ Section)
 FloatingPointModel="strict" (’Floating Point’ Section)
 ExtendSinglePrecisionConstants="true" (’Floating Point’ Section)
 UseMkl="mklParallel" (’Libraries’ Section)
When I compile the code I'm obtaining the following error output:
LINK: fatal error LNK1561: entry point must be defined
I'm following a manual to develop this dll for the user-defined subroutine, I'm my configuration differs from the manual because I have selected "Use Free Format" instead of fixed format with 132 characters length.
Does anyone have any idea of how to get rid of this error?
Steve_Lionel
I would guess that you created an executable project type rather than a DLL project type. Start over and make sure the project type is DLL.
Thanks Steve, it works now
Luis
WenLong__Li
Hi
I have the same problem with Luis and we may both use the Anura3D.
I tried Steve's method ,but it does not work ,my configuration type has already been the Dynamic-link Library.
I still get the error output
LINK:fatal error LNK1561: entry point must be defined
Would be great to get response on how to fix it.
Steve_Lionel
If you get that error, you have the wrong project type, even if you think otherwise. Start over - create a new DLL project and add your sources to it.
