29487 Discussions
DO CONCURRENT crash with OPENMP with Linux ifort 2024.2
kay-diederichs
The latest ifort 2024.2 on Linux produces the output
 22.19008 37.32648 39.86396
173.5668 235.1864 234.4165
133.3740 193.3915 193.9088
forrtl: severe (174): SIGSEGV, segmentation fault occurred
with the following simple code. It prints the correct result when using the array assignment, but crashes when calculating the same thing with DO CONCURRENT. Or am I doing something wrong?
Compilation is just
ifort -qopenmp test.f90
INTEGER i,nd
REAL a0(3,3),b(3,3),vc(3,1000),vd(3,1000)
CALL RANDOM_NUMBER(vd)
vd=vd*100
CALL RANDOM_NUMBER(a0)
CALL RANDOM_NUMBER(b)
vc=MATMUL(a0,REAL(NINT(MATMUL(b,vd))))
DO i=1,3
PRINT*,vc(:,i)
END DO
DO CONCURRENT(i=1:nd)
vc(:,i)=MATMUL(a0,REAL(NINT(MATMUL(b,vd(:,i)))))
ENDDO
DO i=1,3
PRINT*,vc(:,i)
END DO
END
A colleague tells me that with his 2019 ifort there is no bug. Any insight?
Thanks, Kay
Devorah_H_Intel
kay-diederichs
an update: latest ifx 2025.1 on Linux does not work correctly unless the -qopenmp option is used.
If no options are used, the program stops output after printing the first 3 lines. Using 'top' , I see that it consumes 6% CPU. I can kill it with kill -9 , but not with ctrl-C in the shell that runs the it.
kay-diederichs
This bug is not in ifx 2025.0 . But ifx has other bugs that prevent us from using it. As soon as I have such minimal reproducers as the one I posted above for ifort, I will post them here.
As long as it not an official policy that ifort is no longer discussed here in this forum, I think it makes sense to post bug reports about it.
