29386 Discussions
DOS commands used to link IMSL libraries
postaquestion
I don't know whatDOS commands are used to link imsl library in a program on UNIX.
In the program I wrote ..include 'link_f90_static.h' and use _INT.., but when I create .out doesn't work because it can't find the path of library.
Please help & best regards.
UNIX?
If you are using Intel Visual Fortran and open your command prompt session with the "Fortran Build Environment..." shortcut, and have IMSL installed from Intel Visual Fortran Professional Edition with IMSL, then the path to the IMSL libraries is set up automatically. I will note that the name link_f90_static.h is, in version 10.x, link_fnl_static.h (a change in IMSL 6.0).
What part of your environment doesn't match the above?
