OpenMP Hello World.
Intel_C_Intel
I am sorry for asking suck a simple question but I am having hard time to execute simple program using multiple cores. I am using Intel Visual Fortran Compiler 9.1 Professional with Microsoft Visual Studio 2005, and I have Intel Core 2 Duo Processor. Here is the code which I am compiling.
program OpenMP
use omp_lib
implicit none
!$omp parallel
print *, 'Hello World'
!$omp end parallel
call system("PAUSE")
end program OpenMP
But I am all the time getting just one Hello World instead of two. Can anyone tell me what I am doing wrong?
Thanks in advance.
Mark_Westwood
Hi
I use VS 2003 and Intel Fortran 10.x but I guess this might help:
From the project menu select project Properties, select the Fortran branch, then Language. Here you'll find a line with the name 'Process OpenMP Directives'; I guess that you have not set this to Generate Parallel Code.
Check out the documentation for further detail.
Mark Westwood
TimP
Besides checking your project properties (enable /Qopenmp for compile and link), you might start with one of the examples posted on the web.
Intel_C_Intel
Thanks. I have one more question, what exactly going to happen with shared variables when they step in to parallel region, I mean what value they would have. Because right now during debugging I can see that they have totally different values inside parallel region.
For example:
REAL*8 some_num = 10;
INTEGER other_number = 5;
INTEGER I;
!$omp parallel default(none)&
!$omp shared(some_num, other_number)
!$omp do lastprivate(i) schedule(static, 2)
DO I = 2, 10
some_num = some_num + other_number
other_number = other_number + i
END DO
!$omp end do
!$omp end parallel
NOTE: some_number and other_number are not eq to 5 and 10 inside parallel region why?
Thanks in advance.
TimP
As you declared those variables shared, each thread tries to update the same (only) copies of the variables. There is no guarantee about the order of events, beyond the partial control implied by your schedule clause. This is called a race condition. The result will depend, among other things, on how many threads you specify.
You could make the other_number consistent by specifying a reduction, and changing the code so that it is not a SAVEd variable (implied by initializing at declaration).
If you used Qparallel and Qpar-report, instead of OpenMP, you might get some diagnostics (possibly obscure) about what is wrong with attempting to parallelize this.
Intel_C_Intel
Thanks for answering, what will happen if I will do something like this:
 DO N=1,10
!$omp shared(N)
!$omp do lastprivate(L, I, J, K) schedule(static,5)
DO L=2,10
I = N + L !here I and L are shared but not N.
J = 0
DO K=L,10
J = J + 1 !here J is shared would it work fine?. &nbs p;
END DO
END DO
!$omp end do
!$omp end parallel
END DO
What value would have I and J? is it race condition? And in which case I should use !$omp atomic ?
Thanks in advance.
