29249 Discussions
Debugger diplaying variables in hexadecimal
Stephen_Painchaud
I have a problem with a certain solution or projectcausing VS2005 and VS2008 to crash while debugging Fortran. I have learned to work around the crash, but the VS2008 debugger is now displaying variables in hexadecimal, which I dont find to be very useful. I have checked in options for a switch back to decimal, but have found nothing. Does anyone know where this switch is. I am using IF 11.1.046 (IA-32).
jimdempseyatthecove
You can add a toolbar button to toggle format
or
hover the mouse pointer over the hex number and right-click (left click if using left handed mouse) then you will get a pop-up in which you can change the view format to decimal (or hex, ...).
Jim Dempsey
jimdempseyatthecove
or
Jim Dempsey
Stephen_Painchaud
or
Jim Dempsey
Thanks, that solved the problem.
