Debugging my Console Application displays garbage (Windows 10, win32)
I call this a “question” but its may well be a “bug report”
It shows corrupted variables though some but not all can WRITE correctly.
- Fortran is calling LAPLIBO, my C++ static library (which also calls Alglib C++).
- Issue occurs both calling LAPLIB, a DLL equivalent
- I build via CMAKE
See Below, where I set buf=”” but it is showing as garbage
Failed attempts to fix include:
- Gutting debug/ release and rebuilding
- And again and again
- Loading the same VS and Fortran on another similar notebook
It would be convenient for now if did not have to
- Download the whole project
- Do a very tedious and not guaranteed downgrade lf both VS and Fortran
I am hoping someone is both familiar with the issue and, perhaps, has a fix
Dell M4800 and Windows 10
- Microsoft Visual Studio Community 2015
- Version 14.0.25424.00 Update 3
- Microsoft .NET Framework
- Version 4.6.01038
- Visual C++ 2015 00322-20000-00000-AA674
- Microsoft Visual C++ 2015
- Intel® Parallel Studio XE 2016 Update 1 Composer Edition for Fortran Windows* Package ID: w_comp_lib_2016.1.146
- Intel® Parallel Studio XE 2016 Update 1 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2015, Version 16.0.0058.14, Copyright © 2002-2015 Intel Corporation. All rights reserved.
Regards, Peter
I'm going to take a guess and ask if you have optimization enabled for this configuration. If so, it would explain what you are seeing. I was working on another customer's project yesterday where there were similarly strange results in the debugger. Even though it was a Debug configuration, /O2 had been set. This will make viewing of locals in the debugger unreliable.
链接已复制
Judging from the screenshot I have a question and a remark:
- Did you specify two arguments when starting the debug session? You can do that from within Visual Studio
- Strings that are not set generally have rubbish as their content, they are not initialised to spaces
Yes, I specified two args. Not only that the first the input file "filei" enabled the correct files to be loaded. But "fili" displayed garbage in the debugger. As I said, some strings displaying as garbage are garbage as they Parse into many more fields than Imexpect.
And you will have seen "buf="" being displayed as garbage in the attached image
Okay, the problem may be in GETARG then. Is that a C++ routine? Could it be that it does not have the right interface or the calling program does not "know" the interface?
The problem must be in GETARG then.
Could you try instead these lines to retrieve the arguments:
call get_command_argument( 1, filei ) call get_command_argument( 2, fileo )
or the other way around (I am not entirely sure in what order you specify them ;). That way you exclude the problem and you can see whether the values of character strings are shown correctly or not.
This is really odd. But this is clearly a different issue than I thought. The program works fine, just the debugger is having trouble showing the right information - at least, that is my conclusion at this moment. I will have to leave this to people more knowledgeable on this subject.
Did I say:
Thanks Arjen.
I look forward to "people more knowledgeable". Morining Steve!
Note, as I said, some variables actually are being corrupted. I just have not managed to prove it.
You might get some more information by displaying the data in hex. Various bit patterns have specific meanings but you can only really see them in hex mode.
I can only convert the non strings to text. Will that help?
Many thanks Steve, you were right.and I was a ?????
With some help I am converting to CMAKE as was spending more time sorting Visual Studio parameters issues than actual programming.
So I had better tweak some CMakeLists.txt files. But I will still try to stick with CMAKE!
Peter
I can overwite my duplicate reply (as here), but how can I delate iit?
Users can't delete posts. You can ask us to do so.
