Debugging my Console Application displays garbage (Windows 10, win32)
PeterTheRascal
ビギナー
4,184件の閲覧回数
I call this a “question” but its may well be a “bug report”
It shows corrupted variables though some  but not all can WRITE correctly.
  • Fortran is calling  LAPLIBO, my C++ static library (which also calls Alglib C++).
  • Issue occurs both calling LAPLIB, a  DLL equivalent
  • I build via CMAKE
See Below, where I set buf=”” but it is showing as garbage
Failed attempts to fix include:
  • Gutting debug/ release and rebuilding
  • And again and again
  • Loading the same VS and Fortran on another similar notebook
It would be convenient for now if did not have to
  • Download the whole project
  • Do a very tedious and not guaranteed downgrade  lf both VS and Fortran
I am hoping someone is both familiar with the issue and, perhaps, has  a fix
Dell M4800 and Windows 10
  • Microsoft Visual Studio Community 2015
  • Version 14.0.25424.00 Update 3
  • Microsoft .NET Framework
  • Version 4.6.01038
  • Visual C++ 2015   00322-20000-00000-AA674
  • Microsoft Visual C++ 2015
  • Intel® Parallel Studio XE 2016 Update 1 Composer Edition for Fortran Windows*     Package ID: w_comp_lib_2016.1.146
  • Intel® Parallel Studio XE 2016 Update 1 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2015, Version 16.0.0058.14, Copyright © 2002-2015 Intel Corporation. All rights reserved.
Regards, Peter
0 件の賞賛
1 解決策
Steven_L_Intel1
従業員
4,184件の閲覧回数
I'm going to take a guess and ask if you have optimization enabled for this configuration. If so, it would explain what you are seeing. I was working on another customer's project yesterday where there were similarly strange results in the debugger. Even though it was a Debug configuration, /O2 had been set. This will make viewing of locals in the debugger unreliable.
元の投稿で解決策を見る
15 返答(返信)
Arjen_Markus
名誉コントリビューター II
4,184件の閲覧回数
Judging from the screenshot I have a question and a remark:
  • Did you specify two arguments when starting the debug session? You can do that from within Visual Studio
  • Strings that are not set generally have rubbish as their content, they are not initialised to spaces
PeterTheRascal
ビギナー
4,184件の閲覧回数
Yes, I specified two args. Not only that the first the input file "filei"  enabled the correct files to be loaded.  But "fili" displayed garbage in the debugger. As I said, some strings displaying as garbage are garbage as they Parse into many more fields than Imexpect.
And you will have seen "buf="" being  displayed as garbage in the attached  image
Arjen_Markus
名誉コントリビューター II
4,184件の閲覧回数
Okay, the problem may be in GETARG then. Is that a C++ routine? Could it be that it does not have the right interface or the calling program does not "know" the interface?
PeterTheRascal
ビギナー
4,184件の閲覧回数
Here are some images "proving" fine input "filo" is dipalyed as rubbish but "works" (not really proved!)
Peter
Arjen_Markus
名誉コントリビューター II
4,184件の閲覧回数
The problem must be in GETARG then.
Could you try instead these lines to retrieve the arguments:
call get_command_argument( 1, filei )
call get_command_argument( 2, fileo )
or the other way around (I am not entirely sure in what order you specify them ;). That way you exclude the problem and you can see whether the values of character strings are shown correctly or not.
PeterTheRascal
ビギナー
4,184件の閲覧回数
Arjen
Thanks for your interest
get_command_argument is not different. The screen dump attached gived more evidience file in "fini" is loading OK
Arjen_Markus
名誉コントリビューター II
4,184件の閲覧回数
This is really odd. But this is clearly a different issue than I thought. The program works fine, just the debugger is having trouble showing the right information - at least, that is my conclusion at this moment. I will have to leave this to people more knowledgeable on this subject.
PeterTheRascal
ビギナー
4,184件の閲覧回数
Did I say:
Thanks Arjen.
I look forward to "people more knowledgeable".  Morining Steve!
Note, as I said, some variables  actually are being corrupted.  I just have not managed to prove it.
Simon_Geard
新規コントリビューター I
4,184件の閲覧回数
You might get some more information by displaying the data in hex. Various bit patterns have specific meanings but you can only really see them in hex mode.
PeterTheRascal
ビギナー
4,184件の閲覧回数
I can only convert the non strings to text. Will that help?
PeterTheRascal
ビギナー
4,184件の閲覧回数
sorry, I forgot the screen dump.
Steven_L_Intel1
従業員
4,185件の閲覧回数
PeterTheRascal
ビギナー
4,184件の閲覧回数
Many thanks Steve, you were right.and I was a ?????
With some help I am converting to CMAKE as was spending more time sorting Visual Studio parameters issues than actual programming.
So I had better tweak  some CMakeLists.txt  files.  But I will still try to stick with CMAKE!
Peter
PeterTheRascal
ビギナー
4,184件の閲覧回数
I can overwite my duplicate  reply (as here), but how can I delate iit?
Steven_L_Intel1
従業員
4,184件の閲覧回数
Users can't delete posts. You can ask us to do so.
返信
