29489 Discussions
Debugging - "breakpoint will currently not be hit. invalid file line"
rafadix08
I am having this message when I include a break point in my code.
I have tried some recommendations I found on the web like deleting the solutions file, etc...
Does anyone know how to fix this?
Rafael
rafadix08
I think this could be additional information.
I am copying my build file and the output I get when I run the program in debug mode.
Build file:
Deleting intermediate files and output files for project 'Estimation_SMM', configuration 'Debug|Win32'.
Compiling with Intel Visual Fortran 11.0.075 [IA-32]...
ifort /nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug" /object:"Debug" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc8 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio 8VCbin" "C:Documents and SettingsRafael Dix CarneiroMy DocumentsThesisNew Fortran CodesEstimationEstimation Weight IdentityGlobal_Data.F90"
ifort /nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug" /object:"Debug" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc8 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio 8VCbin" "C:Documents and SettingsRafael Dix CarneiroMy DocumentsThesisNew Fortran CodesEstimationEstimation Weight Identityminim.f90"
ifort /nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug" /object:"Debug" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc8 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio 8VCbin" "C:Documents and SettingsRafael Dix CarneiroMy DocumentsThesisNew Fortran CodesEstimationEstimation Weight IdentityEmax_MOD.F90"
ifort /nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug" /object:"Debug" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc8 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio 8VCbin" "C:Documents and SettingsRafael Dix CarneiroMy DocumentsThesisNew Fortran CodesEstimationEstimation Weight IdentityLoss_Function_MOD.F90"
ifort /nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug" /object:"Debug" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc8 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio 8VCbin" "C:Documents and SettingsRafael Dix CarneiroMy DocumentsThesisNew Fortran CodesEstimationEstimation Weight IdentityMain.F90"
Linking...
Link /OUT:"DebugEstimation_SMM.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"C:Documents and SettingsRafael Dix CarneiroMy DocumentsVisual Studio 2005ProjectsEstimation_SMMEstimation_SMMdebugestimation_smm.exe.intermediate.manifest" /DEBUG /PDB:"C:Documents and SettingsRafael Dix CarneiroMy DocumentsVisual Studio 2005ProjectsEstimation_SMMEstimation_SMMdebugestimation_smm.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"C:Documents and SettingsRafael Dix CarneiroMy DocumentsVisual Studio 2005ProjectsEstimation_SMMEstimation_SMMdebugestimation_smm.lib" "DebugGlobal_Data.obj" "Debugminim.obj" "DebugEmax_MOD.obj" "DebugLoss_Function_MOD.obj" "DebugMain.obj"
Link: executing 'link'
Embedding manifest...
mt.exe /nologo /outputresource:"C:Documents and SettingsRafael Dix CarneiroMy DocumentsVisual Studio 2005ProjectsEstimation_SMMEstimation_SMMdebugestimation_smm.exe;#1" /manifest "C:Documents and SettingsRafael Dix CarneiroMy DocumentsVisual Studio 2005ProjectsEstimation_SMMEstimation_SMMdebugestimation_smm.exe.intermediate.manifest"
Estimation_SMM - 0 error(s), 0 warning(s)
Output after running on debug mode:
'estimation_smm.exe': Loaded 'C:Documents and SettingsRafael Dix CarneiroMy DocumentsVisual Studio 2005ProjectsEstimation_SMMEstimation_SMMDebugestimation_smm.exe', Symbols loaded.
'estimation_smm.exe': Loaded 'C:WINDOWSsystem32ntdll.dll', No symbols loaded.
'estimation_smm.exe': Loaded 'C:WINDOWSsystem32kernel32.dll', No symbols loaded.
'estimation_smm.exe': Loaded 'C:Program FilesIntelCompiler11.0�75fortranlibia32libiomp5md.dll', Binary was not built with debug information.
'estimation_smm.exe': Loaded 'C:WINDOWSsystem32imagehlp.dll', No symbols loaded.
'estimation_smm.exe': Loaded 'C:WINDOWSsystem32msvcrt.dll', No symbols loaded.
First-chance exception at 0x7c812afb in estimation_smm.exe: 0xA1A01DB1: 0xa1a01db1.
The program '[2904] estimation_smm.exe: Native' has exited with code 0 (0x0).
TimP
Quoting - rafadix08
This is strange. It is the debug version of the library, and there is a companion .pdb, at least in the current version. If your version is missing some debug facilities (linux versions had that problem at that time), maybe you could consider updating.
rafadix08
Quoting - tim18
I am able to include breakpoints and debug other programs. Actually, that problem started when I created a new version of a project and started to debug it. I can still debug the older version, include breakpoints, etc... But in the new version I have this problem of "breakpoint will currently not be hit. invalid file line".
I tried lots of things with this new version, for instance delete the solution file, the pdb file, delete the project and create it again, etc... The problem persisted after each one of these actions.
If this is relavant, I am using Microsoft Visual Studio 8.
Are you running the same EXE that was built? What does it say for "Command" under the project property Debugging > Command?
rafadix08
Hi Steve,
It says $(TargetPath)
I am doing everything as usual: build the application using Visual Studio 8 (debug mode), insert break points and click on the play icon (start debugging). Right after I click at the play icon (start debugging) the red ball for the breaking point location becomes hollow with the message "breakpoint will currently not be hit. invalid file line".
Please let me know if you need further info.
Thanks a lot,
Rafael
Delete the entire Debug subfolder and rebuild. The PDB may have been corrupted.
rafadix08
I have already tried that, many times. The problem persists.
Les_Neilson
Valued Contributor II
It's a long shot but ...
If in VS youdo Window->Windows this will give a popup showing the name and path of each file currently opened. Check that the file you have open (where you want to put the breakpoints) is the one that is compiled with the project.
In the solution explorer window highlight the filename and press F4 will show the full path of the file.
Les
rafadix08
Quoting - Les Neilson
Les
Les, thanks for the reply. The paths are fine...
I had already checked that in the Build file.
rafadix08
Quoting - rafadix08
What is curious is that some breakpoints work and some just don't.
Any other suggestion?
I already tried to unistall and install Fortran+Visual Studio and still get the same error. Maybe there is some file that was corrupted and is not being erased by uninstalling them?
Seems unlikely to me that it is an installation issue. It could be an error in source line correlation information from the compiler. Can you attach a zip of the project with instructions on how to reproduce the problem?
