Declared variables in MODULE are showing up as undefined variables in main program and its subroutines
Coyote__Riley
Quick background:  I developed a program two years ago in Fortran to perform a set of calculations based on structured text file input. I'll refer to this program as "Program A". Program A's Release *.exe was last used successfully in 2018. Fast forward to September 2019, and Program A's Release *.exe was used for the first time since 2018 but now no longer works correctly, even when using input text files that had been previously run without problems.
The previous PC with the combination of Visual Studio and Intel Visual Fortran used to develop, build and compile Program A's Release *.exe was reclaimed by IT earlier this year. So I have just installed Intel(R) Visual Fortran Composer XE 2013 SP1 Update 6 Integration for Microsoft Visual Studio 2010 on a PC, with the intent on debugging the source to figure out why the program no longer works well.
My current problem:
I opened up the old Program A project solution in the recently installed IVF and it was converted successfully into the new IDE.
Now when I debug Program A, I see that some variables and arrays declared in a MODULE are showing up as Undefined in the main PROGRAM and its subroutines (Undefined variable 'x' or Undefined pointer/array 'y'), but some of these do report values.
I am not sure why some of the MODULE variables & arrays have values and others are Undefined, when in the last IDE the compiled source code executed without any issue.
Excerpt of MODULE and main PROGRAM are reproduced below:
MODULE CONSTANTS_MODULE
    USE IFPORT
    USE IFWIN
    USE, INTRINSIC :: IEEE_ARITHMETIC
    IMPLICIT NONE
    INTEGER, PARAMETER :: NCOMP=8
    INTEGER, PARAMETER :: NPTS=48
    INTEGER, PARAMETER :: NFAC=1
    INTEGER, PARAMETER :: NRESTOP=32
    REAL*8 :: cokeRho
    REAL*8, PARAMETER :: piconst=3.14159
    REAL*8 :: MWcomp(NCOMP)
    DATA MWcomp / 12.0107, 18.0152, 28.0101, 44.0095, 2.01588, 31.9988, 28.0134, 39.948 /
    REAL*8, DIMENSION(1:400) :: inarr, inarr2, inarr3, inarr4, inarr5
    REAL*8, DIMENSION(1:400) :: inarr6, inarr7, inarr8, inarr9, inarr10
    INTEGER, PARAMETER :: CASENUM=10
    LOGICAL, DIMENSION(:,:), ALLOCATABLE :: GOPRINT
    REAL*8, DIMENSION(0:NPTS*NFAC,NRESTOP) :: HOLDPRINT
    SAVE
END MODULE CONSTANTS_MODULE
PROGRAM MAINDRV
    USE CONSTANTS_MODULE
    IMPLICIT NONE
END PROGRAM MAINDRV
Note: There are many more variables and arrays declared in the module which I am not showing.
During debug while I am in PROGRAM MAINDRV:
1. The allocatable array GOPRINT shows up as an Undefined pointer/array
2. All of the integer parameters NCOMP, NPTS, NFAC, NRESTOP, CASENUM show up as Undefined variables
3. The REAL*8 parameter piconst shows up as Undefined variable
4. The REAL*8 array MWcomp(NCOMP) shows up as Undefined variable
5. The REAL*8 arrays inarr, inarr2, inarr3, inarr4, inarr5, inarr6, inarr7, inarr8, inarr9, inarr10 are populated with values
6. The array HOLDPRINT with dimension (0:NPTS*NFAC,NRESTOP) has correct dimension (0:48,32) and is populated with values
7. The REAL*8 variable cokeRho is populated with value
The main program and its subroutines depend on all of the variables and arrays that are defined in CONSTANTS_MODULE. How do I get all of the module variables and arrays to be available in the main program?
I have tried researching online and have not been able to figure this one out yet. I am probably missing something simple, but I am not a professional programmer and do not code often (as you can see it has been two years since I last coded in Fortran). I am wondering if some syntax has changed since I last coded in Fortran, or if there is some project option that needs to be toggled to a particular setting, etc.
Thanks in advance for any help you can provide on the subject.
Steve_Lionel
It's only the debugger that's giving you trouble, right? The program still works?
If I recall correctly, the debugger will see only module variables that are used in the current scope. You should be able to access other variables using the syntax modname::varname in a QuickView pane.
Coyote__Riley
Thanks for your reply Steve. It was not just the debugger giving me trouble; the program was not working either. I thought it had something to do with module variables/arrays not being defined in the main program, since that is what the debugger was showing. Turns out the program was modified and the input file was outdated. With the proper input file the program worked like a charm.
Rowe__Ed
I have a similar problem - is it OK to continue this thread, or should I start a new one? I have a program that worked OK a couple of years ago. Now, a variable declared in a module becomes undefined within a subroutine, even though the subroutine USEs this module so the variable should be in scope. I've made a slimmed down version of the code to illustrate the issue. If I put a breakpoint in at "NumDates = NumObservationDates", the watch says "Undefined variable NumObservationDates".
Since writing the original code I've got a new version of the compiler, I'm now running: Intel® Parallel Studio XE 2018 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2015, Version 18.0.0033.14
Perhaps I have got one of the settings wrong. I've tried:
Local Variable Storage = Default Local Storage
Local Variable Storage = All Variables SAVE (/Qsave)
I've also tried just running the exe (ouside the debugger) but it behaves the same.
I'm not brilliant at Fortran but I thought I understood this - that variables declared in a module are kept in memory. I'd be grateful for any advice.
Ed
program RunMADOC
    use SetUpMADOC
    implicit none
    external MADOC
    call MADOC()
end program RunMADOC
subroutine MADOC()
    use SetUpMADOC
    implicit none
    integer :: NumDates
end subroutine MADOC
module SetUpMADOC
    implicit none
    integer, parameter :: NumObservationDates = 1
 end module SetUpMADOC
andrew_4619
See the Option on project setting> fortran> debug
Used in the Program (/debug-parameters:used)
It then includes debug symbols for parameters where they are used,
If you step over  the line NumDates gets the correct value from the parameter, yes?
Rowe__Ed
Yes that's sorted it. It wasn't that the parameter value was undefined, it was that the debugger wasn't displaying the value. And when I realised that, I went on to find the bug in my code that was making the exe behave unexpectedly.
Many thanks Andrew
