29253 Discussions
Default orientation of the paper, for printer
andriasoa
Print graph on a printer, I use structure T_PRINTDLG and the
PrintDlg function. See the PrintFile_1.f90 file attached.
By Default, the orientation is in portrait.
Could you please tell me. How to change (in the program) the orientation
by Default into landscape?
I am using Compaq Visual Fortran 6.6.
Thank you for your help.
Andriasoa
nijhuis
subroutine
test
use
ifwin
implicit none
type
(T_PRINTDLG) pd
type
(T_DEVMODE) devm
integer
ldevm, alloc_stat
integer
, allocatable :: idevm(:)
devm%field1.dmOrientation= DMORIENT_LANDSCAPE
devm%dmFields = DM_ORIENTATION
! Indication of filled orientation field
ldevm = sizeof(devm)
allocate(idevm(ldevm), stat=alloc_stat)
call CopyMemory(loc(idevm), loc(devm), ldevm)
pd%hDevMode =
loc(idevm)
! fill other pd fields
deallocate(idevm) ! after pd has been used
end program test
I am not sure about the used allocation. I have used T_DEVMODE to retrieve some information in an already filled structure. In that case an integer handle is known and the following code is used:
Code part:
type(T_DEVNAMES) devname
type(T_DEVMODE) devmode
integer idevn, idevm, jdevm, ldevm
! call subroutine to retrieve a T_DEVNAME and a T_DEVMODE structure.
! the integers idevn and idevm arehandles to the structures
call getpr(idevn, idevm)
ldevm = sizeof(devmode)
jdevm= GlobalLock(idevm)
call CopyMemory(loc(devmode), jdevm, ldevm)
! Get number of copies
ncopy = devmode%dmCopies
! Get orientation
orient = devmode%field1%dmOrientation
retval = GlobalUnlock(idevm)
retval = GlobalFree(idev m)
subroutine
test
use
ifwin
implicit none
type
(T_PRINTDLG) pd
type
(T_DEVMODE) devm
integer
ldevm, alloc_stat
integer
pd%hDevMode =
loc(idevm)
end program test
Code part:
! Get orientation
retval = GlobalFree(id evm)
I am not sure if in the first example also GlobalLock etc. has to be used, but I hope you have with these examples enough information to make a working piece of software.
Guus
nijhuis
Oh!The first part ofmy message has disappeared.
I believeit looks like this:
The orientation can be set in a derived type T_DEVMODE of which the handle can be set in hte hDevMode field of the T_PRINTDLG structure.
I will illustrate the use of it with the following example:
(See the prior message for the rest of the story)
Guus
Look at the provided MISCFORPRINT sample to see how this is done. You may want to use the code provided here instead of writing your own.
nijhuis
Sorry for the mash of code in my first reply , butsomething went wrongwhen using the "SRC" button.
Guus
andriasoa
Thank you!
