29650 Discussions
Viewing array components in a derived type in Array Visualizer
larsm
Intel_C_Intel
Yes it's true that support for viewing arrays of derived types is not implemented. We currently don't have any plans to implement it; till now I don't think we've had anyone request this feature!
If you would file a feature request with Premier Support, that would help us better track this. (And you will get notified once it's available.)
It is possible to add some code to your program so that arrays of derived types can be displayed with Array Visualizer. See the sample program: Array Visualizer/Samples/Fortran/Simple.
John
larsm
Im not sure that we are discussing the same thing.
Just to make it clear:
My concern is to be able to view an array component of a derived type when debugging a normal Fortran program like this:
TYPE mytype
REAL, DIMENSION(1:100) :: a
END TYPE mytype
TYPE(mytype) :: b
. Define b somehow here.
How can view b%a in the debugger here?
Im sure this must be a common case and will be even more so when the parameterized derived types and object-oriented features from Fortran 2003 will be implemented.
It works very well in CVF (I can just type in b%a). How do you do the corresponding thing here? It seems overkill to have to declare an array of the same type and shape, that is not in a derived type, and assign b%a to it, to be able to view it in the debugger. Have I missed something trivial?
Best wishes
Lars M
Intel_C_Intel
Yes, we're talking about the same thing. Currently in IVF you can't use "View Array" on any derived type even if the type consists just of an array. I agree that this is a common usage; we'll work on adding support for this in a future release.
As a stop-gap you can add some calls to the AV library to view the array. It's not as convenient as clicking "View Array", but it's not that many lines of code. Take a look at the attachment "derivedtype.f90".
John
