공지
29286 토론
Different behavior between ifort 19 and previous versions.
Matthew_H_6
초급자
3,678 조회수
I have a large code (10k+lines) that I am trying to debug. When I run with v19 I have no issues. When I switch to v18 of the compiler I see different behavior. I tried to build a small test case to aid in the debugging but I see identical results between the compilers for the small test case. I am wondering if anyone has any tips or tricks on how to track down errors like this.
The same compilation flags are used for both compilers, and I tested version v17, it behaved the sameway as v18.
0 포인트
15 응답
andrew_4619
명예로운 기여자 III
3,668 조회수
It might help if you have some specific example of a problem you are experiencing. It is hard to make any helpful suggestions from what you have given. Yes I have experience both both versions and no I do not know of any fundamental differences.
0 포인트
Matthew_H_6
초급자
3,666 조회수
I am getting different numerical results. With v19 the code stable, with v18 and prior the code will run for short time but will eventually die. The residual output is different between the two version. It should be nearly identical since the case setup is identical. I have not been able yet to track down why the numerical results are different and which aspect of the code is responsible.
0 포인트
andrew_4619
명예로운 기여자 III
3,658 조회수
A useful first test if it is numerical differences is to switch of optimisations and see if that changes anything. There are a whole load of options that trade accuracy versus speed. Are you comparing like with like?
0 포인트
Matthew_H_6
초급자
3,653 조회수
The same Makefile is used, so the compiler options are identical. I am thinking about generating optimization reports for each version and comparing them to see if differences pop out.
0 포인트
Ron_Green
중재자
3,652 조회수
It is not reasonable to expect optimized code to produce identical results between compiler updates, OS updates, or OS changes, or processor changes. I will upload a presentation for you to read, try the options therein, and it has reference articles for more information on conditional numeric reproducibility.
see attached presentation for assistance.
0 포인트
Matthew_H_6
초급자
3,647 조회수
Thanks, I will take a look. I am not expecting 100% exact answers between versions, but having one version diverge and generate garbage and the other produce correct result is unexpected. I have never experienced this before and have been using ifort for 10+ years. The only reason I noticed the current issue is because I had to run on a system that only had v18, and started to see problems. I went back to a system with v18 and v19 and confirmed that v19 runs correctly and v18 does not.
0 포인트
mecej4
명예로운 기여자 III
3,645 조회수
If constructing a small test case causes the issue to cease to exist, one may have to start at the other end, i.e., with the full code, and pare away parts of the code that are either not executed or are not involved in causing the error. This can involve considerable effort, especially in the beginning, and it is helpful to have tools available to measure and document code coverage, effects of changing compiler options, etc.
You have the option to provide the large code, along with any data needed, and instructions to build and run the program to demonstrate the error. You have to contend with the fact that the larger the code, the fewer the count will be of people willing to look into the problem.
0 포인트
Steve_Lionel
명예로운 기여자 III
3,622 조회수
0 포인트
JohnNichols
소중한 기여자 III
3,611 조회수
Not found, error 404
The page you are looking for no longer exists. Perhaps you can return back to the site's homepage and see if you can find what you are looking for. Or, you can try finding it by using the search form below.
The org site throws a bad site error.
Any chance you could put up the paper I would love to read it.
0 포인트
JohnNichols
소중한 기여자 III
3,586 조회수
0 포인트
Steve_Lionel
명예로운 기여자 III
3,573 조회수
Gah - I put in https but the site works only with http. Link edited.
0 포인트
Ron_Green
중재자
3,552 조회수
unfortunately there is no simple "do this to fix it" for numerical difference issues. Did you try the compiler options in Steve's presentation?
Also, what happens at -O0 between the different compilers? Is this an optimization related difference?
0 포인트
Matthew_H_6
초급자
3,545 조회수
I think it may be an optimization issue/difference between the versions. I am attempting to isolate the routine with the difference in the full simulation. It runs on 1000's of cores, so it is a trial and error hunt with write statements. If I uncover anything useful I will post a follow-up message.
0 포인트
jimdempseyatthecove
명예로운 기여자 III
3,535 조회수
I will assume your code is in multiple source files.
What I suggest to do (instructions in MS VS-speak, you can do the same in Eclipse, make, etc...)
In the solution explorer, Release Build, expand the source folder, multi-select half the files,  right-click on selection, properties, then set the optimization level to none, or /O1 or whatever works).
Build, Run and if you crash or get trash data, the problem is within the unselected files. In this case, select half of the remaining files, set optimization level to non... build and try again.
When you reach a point where you don't crash, then start working to halve the list of un-optimized sources and re-enable optimizations.
What the above procedure is doing is performing a binary search, looking for the source file (or files) having issues with optimization.
Once you've identified the affected file, you can then strategize how to isolate the problem further.
Note, it might be helpful to search this forum for ifort 19 vectorization problems.
Also, should the affected source file(s) when compiled without optimizations, combined with the other files compiled with optimizations, cause little runtime performance issues, Then leave your project with using different optimization levels for different files, and move on.
Jim Dempsey
0 포인트
응답
