29419 Discussions
Difficulty with I/O statement on Fortran Visual Composer XE 2011
kentdeeg
I'm having difficulty getting the followins I/O work:
The OPEN statement is in the main program:
The OPEN statement OPEN( 5, FILE = "H:\\REPMSS\\TX001.TXT", RECL =72, FORM = "FORMATED"
the "X" is in col 6:X , STATUS = "UNKNOWN" )
THe I/O statement is in a subroutine:
THe I.O statement is: READ( 5,5) (CARD( K ), K = 1, 72 )
iN USING THE debug FACILITY,during execution, it HALTSon the READ statement
I am totally stumped,
kentdeeg
DavidWhite
Valued Contributor II
Can you also post the Format statement which has the label 5, and also the declaration for CARD
David
TimP
Are you testing quality of error recovery? If you just want a program to work, correct the spelling of "FORMATTED".
Why set such a short RECL? As the other response said, you would need to show more. Apparently, your array CARD must be an array of single characters.
Depending on other factors, using OPEN on unit 5 could kill the ability of a program to take input from console. It's generally desirable to use OPEN only with units 10 and above, or to use newunit.
