Diffrence between DVF and Intel Fortan compiler XE 12.1
Medawela__Subhani
Currently I am using Intel Fortran Compiler XE 12.1 (Parallel Studio XE 2010 with VS 2010) to edit  the source code of RT3D (A ground water modelling software). But  the manual of the software says to use Digital Visual Fortran.
Could I please know the difference between the compiler I am using and Digital Visual Fortran?
Many Thanks
Subhani
mecej4
Rather than read about an obsolete (but high quality) compiler, just use the compiler you have or the current Intel Fortran compiler and, if you run into problems, you can post details here.
Digital/Compaq Fortran supported Fortran 95 (and some features of F2003). If the RT3D package is in Fortran 95 or Fortran 77, any current compiler should work fine.
Steve_Lionel
You can also read  What are the differences between Compaq* Visual Fortran and Intel Visual Fortran?
I'll comment that Digital Visual Fortran is now 19 years old, and Intel Fortran 12.1 is 7 or 8 years old by now.  I agree with mecej4 that you should just try the compiler you have.
Medawela__Subhani
Thank you very much for the reply.
RT3D package is Fortaran 90. Does this matter?
What I have to do is create a .dll file ( file name: rxns.dll) using this compiler , to combine the edited source code with the RT3D package.
Using IVF 12.1  I created a dll file, but when I am trying to run the batchfile, it gives an error telling “ The procedure entry point- RXNS@60 could not be located in the dynamic link library C:\ ..................\ batchrxn.exe”.            (batchrxn. exe is the file that need to be run). I copied the dll file into the corect location.
Could you please check, what I have done wrong?
Many Thanks
TimP
Fortran 95 covers all of fortran 90. Even if some feature were deleted, compilers including ifort would retain them. I didn't catch whether the dll with missing entry point was prebuilt and meant for DVf. In that case you would require 32bit (ia32) ifort with iface:cvf
Medawela__Subhani
Many Thanks Tim.
The dll file given in tutorials is prebuilt and according to their description, its built using DVF. This demo file works fine without any errors when running the batchfile.
The problem is with the dll I am building using IVF (Anyway I do not have DVF compiler since it is very old) .Then only I get the above error message.
mecej4
I recommend that you build the DLL first and then the EXE, both using the same compiler. This you can do if you have all the sources needed.
If however, you have a DVF-compiled DLL and no source, you will need to tell the Intel compiler to use the CVF/DVF calling convention, by specifying the /iface:cvf flag. The @60 suffix in the missing routine name is a sign that the CVF default convention ("STDCALL") was used in the EXE but not in the DLL. You need to provide more details of what you are trying to do, because it is not productive for us to guess what you have in the source files, batch scripts, etc.
Medawela__Subhani
Thank you very much mecej4. It worked..!!
After specifying the /iface:cvf flag, no any errors were given.
Many Thanks again and I will post here if any errors popped up again during my work. Hope you all will help me.
