29295 Discussions
Direct Access Unformated File: Writting at the last record
Ilie__Daniel
Hello!
I want to see what the maximum size for a direct access unformated file is.
The file is created using the following command:
open(unit=100, file="c: emp est.rec", recl=32, access="direct", form="unformatted", status="unknown", iostat=ios)
I use the /assume:byterecl option, so recl=32 is in bytes. The variable ios is declared as an integer (default kind = 4).
I want to write at the very last record of the file. I assumed this was given by huge(ios)-1, which is (2**31-1) - 1 = 2**31 - 2. The write statement was skiped in the code and nothing was written to the file. What is the maximum record I could write at?
I run WindowsXP SP2 with a NTFS file system. My computer has an IntelP4 3GHz HT CPU and 1Gb RAM
I appreciate any ideas on this.
Daniel.
Steven_L_Intel1
What do you mean "the write statement was skipped"? Do you realize that you're trying to write a file 64GB in size?
Ilie__Daniel
Steve,
I realise that the file is big, butit should be possible to do this.
I guess a better explanation would have been "the write statement had no effect" because the file size remained at zero. I do not claim that this is in anyway a fault, but I would like to know why is this happening.
Daniel.
The source code:
program
main
implicit none
integer :: ios, dat, j
j = -1000
open(unit=100, file="c: emp est.rec", recl=32, access="direct", &
dat =
huge(ios) - 1
write(100, rec=dat)ios
read(100, rec=dat, iostat=ios)j
print*,ios,j
end
program main
Steven_L_Intel1
It is a bug - you should get a run-time error of some sort. Please report this to Intel Premier Support.
If you'll tell me in more detail what you're trying to find out, I can help with other methods.
Ilie__Daniel
We are dealing with large data files 5-10Gb. Some of the data in this files got overwritten.
I have checked the source and did not find any mistakes. I wanted to know what is the maximum record number, I could write at, given that my file is created with an "open" statement as shown in the previous post.
Steven_L_Intel1
The only suggestion I can offer is to find out how much disk space remains on the disk you're using and divide by 32. That would be a theoretical maximim, in practice it would be less.
jimdempseyatthecove
Danielilie,
On the OPEN trysetting BUFFERED='NO'
If the data in the file is overwritten and you suspect a problem in the IVF write statement then you could potentially do one or more ofthe following
a) after every write verify the data
b) after every write verify the file size
c) insert the record number into the record being written
(insert it into something that does not alter the record size. e.g. Name)
Method a) would spot file alteration but unfortunately would require a substantial amount of overhead (increasing after each write).
Method b) would detect a case where a write to next recored address performs an overwrite. This would have a side effect of not altering the file size (assuming entire record overwrites prior data).
Method c) would help detect what data did the overwrite.
Note, for method c) the more places in the record you can replace with the record number marker the better. An I/O of 1 record may be performed in one or more pieces. Distributing the record number throughout the record might help identify additional characteristics of the problem.
Jim Dempsey
Ilie__Daniel
Steve,
Jim,
Thank you for your suggestions. I will try them.
Daniel.
Ilie__Daniel
As a follow up:
I managed to create successfully a 67Gb file. However, I think that something may be wrong with the way the write statement is handled. The explanations follow:
The fist program:
program
main
implicit none
integer :: ios, dat
integer, dimension(8) :: arr_out, arr_in
logical, dimension(8) :: subtract
dat = 0
arr_out = 0
arr_in = 0
subtract = .false.
open(unit=100, file="c:analysis est.rec", recl=32, access="direct", &
open(unit=200, file="c:analysis esult.txt")
dat = 1500000000
do
dat = dat + 1000000
write(200,*)dat
arr_in = -1
call write_out(dat, arr_out)
write(100, rec=dat)arr_out
read(100, rec=dat, iostat=ios)arr_in
if( ios /= 0 )then
write(200,*)"I/O Error: ",ios," at rec: ",dat
exit
else
subtract = (arr_out /= arr_in)
if( any(subtract) )then
write(200,*)"Corruption at record: ",dat
exit
end if
end if
end do
close(unit=200)
close(unit=100)
end
program main
subroutine
implicit none
integer, intent(in) :: dat
integer, dimension(8), intent(out) :: arr_out
integer :: pos
pos = 0
arr_out = 0
pos =
mod(dat,8)
if( pos == 0 )pos = 8
arr_out(pos) = dat
end subroutine
write_out
is used to test if the program can write at very large record numbers. The writing starts at record 1,501,000,000. Each writting operation is followed by a read operation. Finally a comparison is made between what was written and read.
The results file does not show any error mesages. The last number in the file is negative, which means the maximum range for integer(4) was exceeded. This was to be expected.
In conclusion, one can write successfully at record 2,000,000,000. This is confirmed once again by running the followingprogram
program
main
implicit none
integer :: ios, dat
integer, dimension(8) :: arr_in
arr_in = -1
dat = 2000000000
print*,ios,arr_in
end
program main
Indeed, record 2,000,000,000 contains the following information: 0 for seven times and 2,000,000,000 in the 8th position of the record.
These two tests prove that one can write at record 2,000,000,000 without any errors being generated.
However, if you delete the created file test.rec and run this program
program
main
implicit none
integer :: ios, dat
integer, dimension(8) :: arr_in, arr_out
arr_in = -1
arr_out = (/1,2,3,4,5,6,7,8/)
dat = 2000000000
write(100, rec=dat, iostat=ios)arr_out
print*,ios
print*,ios,arr_in
end
program main
then you will see that you cannot write at record 2,000,000,000. This is clearly so as the file test.rec does not increase in size and you get iostat=36 in the following read statement.
I would like to know your oppinion on this. This is clearly some kind of fault. Please note that the file test.rec can reach a size of 67Gb when running the first test case.
Kind regards,
Daniel.
Steven_L_Intel1
You reported this to Intel Premier Support. I agree that it's a bug and have asked that the developers fix it in the future.
