Hello!
I want to see what the maximum size for a direct access unformated file is.
The file is created using the following command:
open(unit=100, file="c: emp est.rec", recl=32, access="direct", form="unformatted", status="unknown", iostat=ios)
I use the /assume:byterecl option, so recl=32 is in bytes. The variable ios is declared as an integer (default kind = 4).
I want to write at the very last record of the file. I assumed this was given by huge(ios)-1, which is (2**31-1) - 1 = 2**31 - 2. The write statement was skiped in the code and nothing was written to the file. What is the maximum record I could write at?
I run WindowsXP SP2 with a NTFS file system. My computer has an IntelP4 3GHz HT CPU and 1Gb RAM
I appreciate any ideas on this.
Daniel.
Steve,
I realise that the file is big, butit should be possible to do this.
I guess a better explanation would have been "the write statement had no effect" because the file size remained at zero. I do not claim that this is in anyway a fault, but I would like to know why is this happening.
Daniel.
The source code:
program
mainimplicit noneinteger :: ios, dat, jj = -1000
open(unit=100, file="c: emp est.rec", recl=32, access="direct", &form="unformatted", status="unknown", iostat=ios)
dat =
huge(ios) - 1write(100, rec=dat)iosread(100, rec=dat, iostat=ios)jprint*,ios,jend
program main
If you'll tell me in more detail what you're trying to find out, I can help with other methods.
We are dealing with large data files 5-10Gb. Some of the data in this files got overwritten.
I have checked the source and did not find any mistakes. I wanted to know what is the maximum record number, I could write at, given that my file is created with an "open" statement as shown in the previous post.
Danielilie,
On the OPEN trysetting BUFFERED='NO'
If the data in the file is overwritten and you suspect a problem in the IVF write statement then you could potentially do one or more ofthe following
a) after every write verify the data
b) after every write verify the file size
c) insert the record number into the record being written
(insert it into something that does not alter the record size. e.g. Name)
Method a) would spot file alteration but unfortunately would require a substantial amount of overhead (increasing after each write).
Method b) would detect a case where a write to next recored address performs an overwrite. This would have a side effect of not altering the file size (assuming entire record overwrites prior data).
Method c) would help detect what data did the overwrite.
Note, for method c) the more places in the record you can replace with the record number marker the better. An I/O of 1 record may be performed in one or more pieces. Distributing the record number throughout the record might help identify additional characteristics of the problem.
Jim Dempsey
Steve,
Jim,
Thank you for your suggestions. I will try them.
Daniel.
As a follow up:
I managed to create successfully a 67Gb file. However, I think that something may be wrong with the way the write statement is handled. The explanations follow:
The fist program:
program
mainimplicit noneinteger :: ios, datinteger, dimension(8) :: arr_out, arr_inlogical, dimension(8) :: subtractdat = 0
arr_out = 0
arr_in = 0
subtract = .false.
open(unit=100, file="c:analysis est.rec", recl=32, access="direct", &form="unformatted", status="unknown", iostat=ios)
open(unit=200, file="c:analysis esult.txt")dat = 1500000000
dodat = dat + 1000000
write(200,*)datarr_in = -1
call write_out(dat, arr_out)write(100, rec=dat)arr_outread(100, rec=dat, iostat=ios)arr_inif( ios /= 0 )thenwrite(200,*)"I/O Error: ",ios," at rec: ",datexitelsesubtract = (arr_out /= arr_in)
if( any(subtract) )thenwrite(200,*)"Corruption at record: ",datexitend ifend ifend doclose(unit=200)close(unit=100)end
program mainsubroutine
write_out(dat, arr_out)implicit noneinteger, intent(in) :: datinteger, dimension(8), intent(out) :: arr_outinteger :: pospos = 0
arr_out = 0
pos =
mod(dat,8)if( pos == 0 )pos = 8arr_out(pos) = dat
end subroutine
write_out
is used to test if the program can write at very large record numbers. The writing starts at record 1,501,000,000. Each writting operation is followed by a read operation. Finally a comparison is made between what was written and read.
The results file does not show any error mesages. The last number in the file is negative, which means the maximum range for integer(4) was exceeded. This was to be expected.
In conclusion, one can write successfully at record 2,000,000,000. This is confirmed once again by running the followingprogram
program
main implicit none integer :: ios, dat integer, dimension(8) :: arr_inarr_in = -1
dat = 2000000000
read(100, rec=dat, iostat=ios)arr_in print*,ios,arr_inend
program mainIndeed, record 2,000,000,000 contains the following information: 0 for seven times and 2,000,000,000 in the 8th position of the record.
These two tests prove that one can write at record 2,000,000,000 without any errors being generated.
However, if you delete the created file test.rec and run this program
program
mainimplicit noneinteger :: ios, datinteger, dimension(8) :: arr_in, arr_outarr_in = -1
arr_out = (/1,2,3,4,5,6,7,8/)
dat = 2000000000
write(100, rec=dat, iostat=ios)arr_outprint*,iosread(100, rec=dat, iostat=ios)arr_inprint*,ios,arr_inend
program main
then you will see that you cannot write at record 2,000,000,000. This is clearly so as the file test.rec does not increase in size and you get iostat=36 in the following read statement.
I would like to know your oppinion on this. This is clearly some kind of fault. Please note that the file test.rec can reach a size of 67Gb when running the first test case.
Kind regards,
Daniel.
