The following text appears in the library reference:
egin{extended_quote}
To get information about one or more files, set the handle to FILE$FIRST and call GETFILEINFOQQ. This will return information about the first file which matches the name and return a handle. If the program wants more files, it should call GETFILEINFOQQ with the handle. GETFILEINFOQQ must be called with the handle until GETFILEINFOQQ sets handle to FILE$LAST, or system resources may be lost."
end{extended_quote}
What kind of system resources? I'm guessing file handles, but would like to know for sure.
链接已复制
! TYPE T_WIN32_FIND_DATA
! SEQUENCE
! integer(DWORD) dwFileAttributes ! knowns DWORD
! TYPE (T_FILETIME) ftCreationTime ! typedefs FILETIME
! TYPE (T_FILETIME) ftLastAccessTime ! typedefs FILETIME
! TYPE (T_FILETIME) ftLastWriteTime ! typedefs FILETIME
! integer(DWORD) nFileSizeHigh ! knowns DWORD
! integer(DWORD) nFileSizeLow ! knowns DWORD
! integer(DWORD) dwReserved0 ! knowns DWORD
! integer(DWORD) dwReserved1 ! knowns DWORD
! character(260) cFileName
! character(14) cAlternateFileName
! END TYPE
FUNCTION file_exists (fname) RESULT (size) IMPLICIT NONE TYPE(T_WIN32_FIND_DATA) :: fdata CHARACTER(LEN=*),INTENT(IN) :: fname ! full pathname to file INTEGER :: size, handle, rval size = -1 handle = FindFirstFile (fname,fdata) IF (handle /= INVALID_HANDLE_VALUE) THEN size = fdata%nFileSizeLow rval = FindClose (handle) ENDIF END FUNCTION file_exists
Paul-Curtis wrote:Here is the Win32 way of geting file information; note that the call to FindClose is required to avoid a memory leak.
Ah. This is good. I've been using the portability library as a bit of a crutch when I have to port to Windows. Thanks for the insight and a detailed alternative.
It seems that GETFILEINFOQQ was in IVF9, but not in IVF11.
I now get the error:
...gfildate.f(47): error #6284: There is no matching specific function for this generic function reference. [GETFILEINFOQQ]
compilation aborted for ...gfildate.f (code 1)
I have tried combinations of:
USE DFLIB
USE IFPORT
USE IFCORE
but they did not help.
How might I get similar functionality in IVF 11?
I'm going to make a guess, though. You're building a 64-bit application and have specified an INTEGER*4 variable for the HANDLE argument. Declare this to be INTEGER(INT_PTR_KIND()) instead and it should work.
I have a problem related to this particular function. When I use it on a 32-bit machine, it works just fine, but on a 64-bit machine it never returns FILE$LAST (so I have to use FILE$ERROR as a condition to exit the loop).
It seems to me that some of the kinds for the INTEGERs defined in IFPORT are not set properly; or that the procedures' arguments were not modified for the 64-bit version ---e.g., JHANDLE_SIZE is set to POINTER_LEN but, the compiler throws a warning for the second argument of PXFSTRUCTCREATE (and the warning goes away when such argument is defined as INTEGER(4)).
