Does seterrormodeqq do anything any more?
Mark_Lewy
Valued Contributor I
I was just trying out the example program 1 for SETERRORMODEQQ in the compiler documentation and it appears that no system prompt appears regardless of the setting of pmode.
This is with a console application (debug/x86) built with XE2015U1 run on Windows 10 Enterprise 1511 x64.
If it doesn't have an effect in modern versions of Windows, I would like to remove it to improve portability.
Kevin_D_Intel
The sample in the User's guide will not produce the required failure to trigger the OS message about Abort, Retry, Ignore unless device B: in your system is one that's capable of generating that system prompt. Unless the system prompt is triggered the example programs can't demonstrate the functionality of SETERRORMODEQQ.
I was unable to synthesize the required prompt on my Windows 8 system with other devices I have/tried. I inquired w/Developers about an example that can demonstrate the routines functionality.
I believe this message still has relevance under newer OSes. I believe it may appear in a scenario where a hard-drive is unreadable, or perhaps a CD-ROM where the media is damaged and not readable.
