29487 Discussions
Does the order of the compiler options matter?
Sanematsu__Paula
I was debugging my Fortran code with some compiler options and, during runtime, the following error came up:
forrtl: severe (194): Run-Time Check Failure. The variable 'readinputfiles_$I3' is being used in 'main.F90(796,10)' without being defined
I changed the compiler options to
 -O0 -g -debug all -ftrapuv -check bounds -check all -traceback -i8
But I can't get the same error (the code was not changed). In addition, I know for sure that one array is being accessed with an out of bounds index, but I also don't get any runtime error. I am wondering whether the order of the compiler options matters? Or maybe I am doing something wrong in my makefile?
Here is my makefile:
debugFFLAGS = -O0 -g -debug all -ftrapuv -check bounds -check all -traceback -i8
debugEXE = debug.exe
# local installation of PETSc
PETSC_DIR=~/software/petsc-3.7.6
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
OBJS = main.o modGlobal.o
# object dependencies
modGlobal.o : modGlobal.F90
main.o      : main.F90 modGlobal.o
debug: ${OBJS}
   -${FLINKER} ${debugFFLAGS} ${OBJS} -o ${debugEXE} ${PETSC_LIB} ${LDLIBS}
Lorri_M_Intel
Changed your options from what?
Also, if this is your whole makefile, your options are only being applied to the link step not the compilation step.
For compilation, you are only getting the default values of all command line options.
                       --Lorri
Sanematsu__Paula
That's part of my problem. I don't remember exactly the options that I had before. However, they were also defined in the variable $debugFFLAGS in the same way as the makefile shown above (so, they were only applied to the link step as you pointed out).
                       --Lorri
I see. This is a Fortran code with MPI. This is my first time compiling an MPI code. Would you be able to provide some guidance or an example on how to add option to the compilation step? Or should I seek help else where?
I really appreciate your help!
Sanematsu__Paula
Since I am using PETSc, the variables FLINKER and FFLAGS must be used in the makefile because they are predefined. When I changed the variable name from debugFFLAGS to FFLAGS, I was able to reproduce the runtime error.
