Dot Operator in Fortran
N_Netto
I've updated a code that I'm working on and something caught my attention. I tried to use dot operator to access some data in a custom type (I was working on C++ just before) and the code... just compiled.
I cannot find anything that says that dot operator has the same function as the percentage operator, except in some old non-standard fortran compilers.
There were some changes in the Fortran standard that allows the dot operator as type accessor?
The following code compiled just fine with ifort 19.0.5, x86, Windows 10.
program DotOperatorTest
    implicit none
    type :: mytype
        real(8)     :: a, b
        integer(4)  :: i, k
    end type
    type(mytype) :: foo
    foo%a = 1.5
    foo.b = 2.0
    foo.i = int(foo.a * foo%b * 3)
    foo%k = foo%i / foo.b
    write(*,'(A,g0)') 'a equals to ', foo%a
    write(*,'(A,g0)') 'b equals to ', foo.b
    write(*,'(A,i0)') 'i equals to ', foo.i
    write(*,'(A,i0)') 'k equals to ', foo%k
    pause
    end program DotOperatorTest
Returning
a equals to 1.500000000000000
b equals to 2.000000000000000
i equals to 9
k equals to 4
Fortran Pause - Enter command<CR> or <CR> to continue.
mecej4
The use of '.' in place of '%' to demarcate components of derived types is a DEC/Compaq/Intel non-standard extension. Its use can make your code behave in odd ways if the code also employs components named 'EQ', 'AND', etc.
mecej4
andrew_4619
As mecej4 says. Put standards checking on (a good plan with new code) and it will get thrown out.
N_Netto
Oh, I see. I was not expecting that new projects have portability options enabled by default.
