29253 Diskussionen
Dummy argument names and interface bodies
IanH
Geehrter Beitragender III
478Aufrufe
Ifort complains that the name `node` inside the interface body for `two` isn't a type.  I think it is getting confused by the use of `node` as a dummy argument in the previous interface body.
MODULE m
  IMPLICIT NONE
  TYPE :: Node
  END TYPE Node
  INTERFACE
    MODULE SUBROUTINE one(node)
      INTEGER :: node
    END SUBROUTINE one
    MODULE SUBROUTINE two(arg)
      TYPE(Node) :: arg
    END SUBROUTINE two
  END INTERFACE
END MODULE m
>ifort /check:all /warn:all /standard-semantics "2016-01-25 node.f90"
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0 Build 20151021
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
2016-01-25 node.f90(13): error #6463: This is not a derived type name.   [NODE]
      TYPE(Node) :: arg
2016-01-25 node.f90(12): warning #6717: This name has not been given an explicit type.   [ARG]
compilation aborted for 2016-01-25 node.f90 (code 1)
3 Antworten
jimdempseyatthecove
478Aufrufe
What happens when type node is not a null type?
Jim Dempsey
Steven_L_Intel1
Mitarbeiter
478Aufrufe
That doesn't change things. You're right that making the dummy argument named node is the key. This is a bug and I will let the developers know - thanks. Issue ID is DPD200381101.
Steven_L_Intel1
Mitarbeiter
478Aufrufe
I expect the fix for this to appear in Parallel Studio XE 2016 Update 3.
Antworten
