28896 Discussions
Dummy procedure pointer in pure function with intent(in) attribute raise compile-time error
s12
Assume the following example:
PROGRAM main
    IMPLICIT NONE
    INTEGER :: res
    INTEGER :: val = 10
    res = func1(val, func)
    CALL sub1(val, func)
CONTAINS
    PURE FUNCTION func(a)
        IMPLICIT NONE
        INTEGER :: func
        INTEGER, INTENT(IN) :: a
        func = a + 1
    END FUNCTION func
    PURE FUNCTION func1(a, ptr)
        IMPLICIT NONE
        INTEGER :: func1
        PROCEDURE(func),POINTER, INTENT(IN) :: ptr
        func1 = func2(a, ptr)   !! Compile-time error: ptr: #6780: A dummy argument with the INTENT(IN) attribute shall not be defined nor become undefined.
    END FUNCTION func1
    PURE FUNCTION func2(b, ptr)
        IMPLICIT NONE
        INTEGER :: func2
        INTEGER, INTENT(IN) :: b
        PROCEDURE(func), POINTER, INTENT(IN) :: ptr
        func2 = ptr(b)
    END FUNCTION func2
    PURE SUBROUTINE sub1(a, ptr)
        IMPLICIT NONE
        INTEGER, INTENT(INOUT) :: a
        CALL sub2(a, ptr) !! All right.
    END SUBROUTINE sub1
    PURE SUBROUTINE sub2(b, ptr)
        IMPLICIT NONE
        INTEGER, INTENT(INOUT) :: b
        b = ptr(b)
    END SUBROUTINE sub2
END PROGRAM main
The call to sub2 in sub1 triggers nothing while compile-time error raised in its corresponding function version. so what's the difference ?
Ron_Green
seems gfortran does not like the calls in the main program:
gfortran repro2.f90
repro2.f90:7:21:
    7 |     res = func1(val, func)
      |                     1
Error: Expected a procedure pointer for argument ‘ptr’ at (1)
repro2.f90:8:19:
    8 |     CALL sub1(val, func)
      |                   1
s12
Yes gfortran complains, but with ifort/ifx, it says nothing when actual argument of the corresponding dummy procedure is not a pointer.
The usage of ptr as actual argument to func2 in func1 doesn't imply any modification but the error message said so.
FortranFan
@s12 wrote:
.. what's the difference ?
A compiler bug, hopefully the Intel Support team will file an incident report for you.
In the meantime, see if you can manage without the "pointer" and "intent(in)" on the procedure argument and do with a more straightforward alternative that is similar to the Fortran "classic" EXTERNAL argument but with an explicit interface:
PROGRAM main
    IMPLICIT NONE
    INTEGER :: res
    INTEGER :: val = 10
CONTAINS
        IMPLICIT NONE
        INTEGER :: func
        func = a + 1
    END FUNCTION func
        IMPLICIT NONE
        INTEGER :: func1
        PROCEDURE(func) :: ptr
    END FUNCTION func1
        IMPLICIT NONE
        INTEGER :: func2
        func2 = ptr(b)
    END FUNCTION func2
        IMPLICIT NONE
    END SUBROUTINE sub1
        IMPLICIT NONE
        b = ptr(b)
    END SUBROUTINE sub2
END PROGRAM main
s12
Thanks to you, Ron and FortranFan. The "classic" alternative works for me. Anyway, hope it'll be fixed soon.
Barbara_P_Intel
Thank you for reporting this, @s12. I filed a bug report, CMPLRLLVM-56500. I'll let you know when it's fixed.
Thank you, @FortranFan, for the workaround.
Another workaround is to remove the PURE attribute from FUNCTION func1.
s12
