29267 Discussions
ERROR: linking vs2015+intel Parallel Studio XE 2016+abaqus2018
Wang__Kaybo
I have installed vs2015, intel  Parallel Studio XE 2016 and abaqus 2018 correctly. I can also develop fortran programm in vs2015 and it works well. but when I try to link vs2015+intel Parallel Studio XE 2016 with abaqus 2018, then
Someone can help me?
First I installed programs, in this sequence:
1 - Visual Studio 2015
2 - Intel Parallel Studio XE 2016 (at finish linked with VS2015)
3 - Abaqus 2018
Then I search  the path for the and ifortvars.bat, seting then on the system variables (variable path):
here is:
D:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.0.110\windows\bin
and
D:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.0.110\windows\bin\intel64
Then I add the path of vcvarsall.bat (VS) and ipsxe-comp-vars.bat (Intel) in launcher.bat(abaqus)
here is:
@call "D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" X64
@call "D:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.0.110\windows\bin\ifortvars.bat" intel64 vs2015
@echo off
"D:\SIMULIA\Commands\abq2018.bat" %*
Finally I run Abaqus Verify, geting something wrong. In the verify.log we can see:
Abaqus Product Install Verification...
Tue Dec 11 13:58:59 2018
Making D:\temp\verify. All verification files will reside in this directory.
Abaqus/Standard
         ...PASS
         Continuing...
Abaqus/Standard with user subroutines
         ...PASS
         Continuing...
Abaqus/Explicit (single precision)
         ...PASS
         Continuing...
Abaqus/Explicit (double precision)
         ...PASS
         Continuing...
Abaqus/Explicit with user subroutines (single precision)
         ...PASS
         Continuing...
Abaqus/Explicit with user subroutines (double precision)
         ...PASS
         Continuing...
Abaqus/Viewer
         ...PASS
         Continuing...
Abaqus/CAE
         ...PASS
         Continuing...
Geometry Translator for CATIA V4
         ...PASS
         Continuing...
Geometry Translator for CATIA V5
         ...PASS
         Continuing...
Direct Geometry Import for CATIA V5
         ...PASS
         Continuing...
Geometry Translator for Parasolid
         ...PASS
         Continuing...
Geometry Translator for Pro/ENGINEER
         ...PASS
         Continuing...
Geometry Translator for SolidWorks
         ...PASS
         Continuing...
Abaqus/AMS
         ...PASS
         Continuing...
Abaqus Interface for MSC.ADAMS
         ...PASS
         Continuing...
Abaqus/Standard parametric studies
         ...PASS
         Continuing...
Abaqus/Explicit parametric studies
         ...PASS
         Continuing...
Abaqus/Design
         ...PASS
         Continuing...
Abaqus Interface for Moldflow
         ...PASS
         Continuing...
Abaqus make utility with Fortran
         ...ERROR
            Abaqus did not complete successfully.
            Please see fortran_make.log for details.
         Continuing...
Abaqus make utility with C++
         ...ERROR
            Please see cpp_make.log for details.
         Continuing...
Abaqus make utility with object code
         ...WARNING
            Abaqus make utility with C++ failed. Verification
            procedure will be skipped.
         Continuing...
Abaqus scripting interface
         ...PASS
         Continuing...
Abaqus analyses using parallelization
      Running thread-based parallel with 2 cpu(s)
            Abaqus/Explicit domain-level parallel
         ...PASS
            Abaqus/Standard direct solver
         ...PASS
         Continuing...
Abaqus/Foundation
         ...PASS
         Continuing...
Abaqus noGUI (CAE/Viewer)
         ...PASS
         Continuing...
Tosca For Abaqus
         ...ERROR
            The Tosca installation was either not specified or
            incorrectly specified. Please refer to the Tosca
            Installation Guide on how to set up Tosca.
         ...ERROR
         Continuing...
Clean-up...
Job files exist. Verification directory D:\temp\verify will not be deleted.
There are something wrong when Abaqus make utility with fortran or c++
Someone can help?
bektas__nurullah
I have the same problem. Did you find solution? Could you share it with me?
