29277 Discussions
Elemental Functions of Derived Types
Richard_Gordon
I couldn't find information on whether it was standards-conforming to have an elemental function with a derived type result. Does anyone know? For example, the following code compiles with no warnings:
Command to compile: ifort /stand:f95 test_derel
[fortran]module mymod
    implicit none
    type mytype
	real(8) :: a
	integer :: i
    end type mytype
contains
    elemental function identity(m1) result(m2)
	implicit none
	type(mytype), intent(in) :: m1
	type(mytype) :: m2
	m2 = m1
    end function identity
end module mymod
program test_derel
    use mymod
    implicit none
    type(mytype), dimension(1:2) :: m1,m2
    m1(1)%a = -1.d0
    m1(2)%a = -2.d0
    m1(1)%i = -1
    m1(2)%i = -2
    m2 = identity(m1)
    write(*,*) m2(1)%a,m2(1)%i
    write(*,*) m2(2)%a,m2(2)%i
end program[/fortran]
And this code produces
-1.00000000000000 -1
-2.00000000000000 -2
Steven_L_Intel1
As far as I know, it is standard conforming. What led you to ask this?
joseph_battelle
From 12.7.1 of F2003 standard:
C1277 All dummy arguments of an elemental procedure shall be scalar dummy data objects and shall
not have the POINTER or ALLOCATABLE attribute.
C1278 The result variable of an elemental function shall be scalar and shall not have the POINTER orALLOCATABLE attribute.
There are no other constraints in the standard that the scalar be of intrinsic type.
Richard_Gordon
Thanks Steve and Joseph.
Steve: For the economics problem I'm working, I have to keep track of a set of statistics that evolves over time. Today's set maps into tomorrow's set, and I wanted to program the mapping somewhat independently of the set of statistics (which may change).
Joseph: Thanks for the part of the standard. I wasn't sure whether a derived type of scalars was itself "scalar". Although I guess since Fortran handles complex scalars that would make sense.
This seems like a powerful feature: you can have an elemental function that in some sense returns an array! Although I am a little nervous using it...
Steven_L_Intel1
Richard,
I asked because I didn't know why you thought this might be nonstandard.
The whole point of elemental functions is to be able to call them with either a scalar or an array and return the appropriate shape result.
