29282 Discussions
Erroneous error #7281: This symbol has multiply declared DEC$ ATTRIBUTES REFERENCE{32|64] attribute with a MODULE SUBROUTINE
FortranFan
Fyi on a support requested at the Intel OSC:
module m
   interface
      module subroutine sub( s )
         !dir$ attributes stdcall, reference, mixed_str_len_arg :: sub
         !dir$ attributes decorate, alias:'sub' :: sub
         character(len=*), intent(in) :: s
      end subroutine sub
   end interface
end module
submodule(m) sm
contains
      print *, s
   end subroutine sub
end submodule
and the compilation response:
C:\temp>ifort /c /standard-semantics /warn:all m.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R
) 64, Version 18.0.1.156 Build 20171018
Copyright (C) 1985-2017 Intel Corporation. All rights reserved.
m.f90(21): error #7281: This symbol has multiply declared DEC$ ATTRIBUTES REFERE
NCE{32|64] attribute. [SUB]
compilation aborted for m.f90 (code 1)
I think the above shown error #7281: This symbol has multiply declared DEC$ ATTRIBUTES REFERENCE{32|64] attribute. should not occur.  The listed attributes in the SUBMODULE with the module subroutine sub are the same as those in the ancestor module.   I believe Intel Fortran should be able to support this.
I have requested a fix for this issue.
