29422 Discussions
Derived type in abstract interface imported by USE reported as missing
Sam_Harrison
I have a module that includes some abstract interfaces. These interfaces use derived types from different modules, and I import these in the abstract interface by an "import" statement of the derived type in question, with the module the derived type is contained in being "use"d in the module itself. This compiles fine on gfortran, but with Intel Fortran 18, I get a "This derived type name has not been declared" error, and I can't figure out why. The module in question is below, and the derived type that throws the error is the "Result" derived type from the "ResultModule" module:
module spcEstuaryReach
    use ResultModule
    implicit none
    type, public, abstract :: EstuaryReach
      contains
        procedure(createEstuaryReach), deferred :: create
        procedure(updateEstuaryReach), deferred :: update
    end type
    abstract interface
        function createEstuaryReach(me) result(r)
            import EstuaryReach, Result
            class(EstuaryReach) :: me
            type(Result) :: r
        end function
        function updateEstuaryReach(me, t) result(r)
            integer :: t
            type(Result) :: r
        end function
    end interface
end module
FortranFan
@Sam Harrison,
Providing a couple of details will greatly increase the likelihood of useful responses: 1) Intel Fortran compiler version and 2) a complete reproducer.
You can try something like this:
module a
! file a.f90
   type :: x
   end type
end module
module b
! file b.f90
   use a, only : x
   type, abstract :: y
   contains
      procedure(Ifun), pass(this), deferred :: fun
   end type
   abstract interface
      function Ifun( this ) result(r)
         import :: x, y
         implicit none
         class(y), intent(in) :: this
         type(x) :: r
      end function
   end interface
end module
C:\temp>ifort /c /standard-semantics /warn:all /stand a.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R
) 64, Version 18.0.1.156 Build 20171018
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
C:\temp>ifort /c /standard-semantics /warn:all /stand b.f90
C:\temp>
Note this particular example works with Intel Fortran compiler 17.0 update 5 as well as 18.0 update 1, so you will need to cross-check the code and with your compiler version.
